Thread: Misfire/hesitation - an update.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Misfire/hesitation - an update.
    Reagarding the misfire I was getting at partial throttle openings, I noticed that it was really bad when lifting off the pedal to change gear. It sounded like a "steam train whoosh". Then a mate of mine came across VX field remedy 1831:
    Complaint:Kind of steam train noise from the engine compartment at around 2500 rpm, especially noticeable at vehicles equipped with automatic transmission.
    Cause:Oscilltion of the EGR actuator.
    Production:New software was introduced with the following VIN Rüsselsheim plant W0L0ZCF3551058394
    The solution seems to be updated software but as an interim, I decided to reduce the EGR gasket to 2 x 8mm holes.
    Result - no more misfire, hesitation or jerkiness. So everything, in my case at least, would point towards the EGR itself and the signals it's receiving.
    Will have to see what VX say on Monday when it goes on Tech-2 but at least I might be heading in the right direction. Hopefully it's not turbo, fuel pump or injector related.
    Good to hear
    Sent from my iPhone using My thumb
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    How about a sticky with the symptoms, troubleshooting and resolution if any?
    Would make an excellent knowledge base.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by lee_umney View Post
    Good idea .
    Drop BigPete a pm and see what he thinks.
    Regular Member robster23's Avatar
    Hastings
    Any update on this? Sounds like exactly my problem!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by robster23 View Post
    Yea, sorry, missed my own thread .
    Gave the dealer a list of what I thought it could be, including rememdy 1831.
    Yes, things have improved, I'd say about 75% better as it still has it's misfire. Their technician wrote that "misfire gone, no smoke". Well, right and wrong Mr Techy. I noticed this morning that it still chucked out clouds of smoke on light throttle when cold but got better when fully warmed up with no smoke that I could see (day time).
    Now to the misfire - as I said, much better but not the 100% result I was expecting. So tomorrow, the blanking plate with 2 x 8mm holes is going back in and together with the software update, I should (?) have the perfect engine .
    Will update in the next few days as Friday night is the next time it goes on a longish run (50 miles) of rural and motorway.
    HTH.
    Edit - these are the threads that got me onto the drilled blanking idea http://vectra-c.com/forum/showthread.php?t=52983 & http://www.vectra-c.com/forum/showth...=51953&page=16. I then started another thread asking if people were still running drilled blanks but no views or replies, so I guess many who tried it have moved on.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Software update + drilled blanking plate = happy Signum driver, for now anyway .
    Will have to see how the drilled plate affects things like the EGR itself and MAP sensor (maifold pressure thingy, not the MAF) .
    Hastings
    Thanks GTR1000, will be putting mine in for software updates on Saturday so hopefully it will help the problem some!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Good luck, let us know what you think .
  1. Y30DT - misfire/stumble/hesitation etc, etc..
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 25th November 2011, 20:06
  2. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  3. Intermittent hesitation / misfire / fuel starve
    By rheumatoid in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 10:35
  4. 2.2 dti misfire hesitation on accelaration
    By ANDYS7571 in forum Engine & Drivetrain
    Last Post: 9th May 2008, 22:38
z30dt egr missfire
