Thread: diesel leak
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default diesel leak
    cars leakin diesel by leak off pipes. My question is. Is it diesel in the leak off pipes
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Yes
    Oct 2009
    Sandwell
    its it then new leak off pipes needed
    is it leaking from the pipe or the join
    Oct 2009
    Sandwell
    Quote Originally Posted by marktaylor View Post
    the join i think got to do injector seals so ill replace the pipes.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Might just need new copper washers mate.
    Oct 2009
    Sandwell
    i thinks it could be when i undone no 4 injector bolt to get the air out when i changed diesel filter. It was very tight and had to move the leak off pipe so i wonder if ive made it come loose. Another question all i can see on ebay is 3.2mm pipe is there 3mm pipe you can by
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Try enealling the washer that's on their an then nipping the bolt back should solve it
    Unless the pipe is actually damaged.
    You could probably buy pipe. But I bet it's just as cheap to get the actual pipe from vxl
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Oct 2009
    Sandwell
    Quote Originally Posted by CritchvxD View Post
    weres the washer though? you on about the injector pipe or leak off pipe because i didnt see a washer on the leak off pipe part
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. diesel leak
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2011, 20:57
  3. diesel leak - any advice
    By mooney in forum Engine & Drivetrain
    Last Post: 13th February 2011, 20:16
  4. Need urgent help with a diesel leak
    By the_wave_rider in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:42
  5. diesel leak ??
    By danceade in forum Vectra C / Signum Troubleshooting
    Last Post: 12th February 2008, 02:09
