Thread: Baromatic pressure sensor,
    Regular Member DTI Dave's Avatar
    Nov 2011
    st annes
    Default Baromatic pressure sensor,
    located next to the airbox, does this sensor have some sort of pipe that plugs in underneeth..... my car is throwing a code with this sensor fault, but there is nothing plugged into the bottom of it nor can i find a pipe that may connect to it/
    any ideas?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi dave
    no there is no pipe , what often happens with these sensors is the electric contacts become oxidised and cause them to go faulty try cleaning the contacts and blow any dirt out of the pipe then replace it sometimes this is all it needs otherwise its a new one pt no 2442 6679 about £55 from the stealers
    Nov 2011
    st annes
    yea i got another off an 04 plate. £20 so hopefuly this sorts it out..
    does this sensor affect performance or mpg etc?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    When mine went faulty it was showing 1.6 volts across the sensor (on Op-com) instead of 4 Volts, but the sensor was still showing the correct barometric pressure.
    Not sure what was happening, but I changed it anyway.
    I'm not sure what difference it made as I also had a faulty turbo at the time too.
    But I think that the ECU needs to know the atmosphere pressure to know if the boost pressure is correct.
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. boost pressure sensor
    By iwtand in forum Engine & Drivetrain
    Last Post: 5th February 2012, 20:43
  3. 2.0 dti boost pressure sensor
    By jono m in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 12:08
  4. boost pressure sensor
    By johnbattams in forum Engine & Drivetrain
    Last Post: 26th March 2009, 17:40
  5. Oil pressure sensor switch
    By crucial in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 09:15
baromatic pressure
would like information on baromatic pressure
