Results 1 to 10 of 21
Thread: Is my Vectra the Only one doing THIS!!!
    Regular Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    Default Is my Vectra the Only one doing THIS!!!
    my 2.2 sri petrol seems to SWALLOW oil. i must be putting in like 5ltrs in 4 weeks, its had a service and new oil and filters. is anyone else's like this or is there something i'm doing wrong?
    Glasgow
    5 litres suggest there is something wrong i would make it a priority to get it checked for leaks etc.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are you getting any blue smoke?
    That is a lot of oil to be going through.
    If it hasnt got an obvious leak. Need to get it checked.
    Could be valve stem seals. Or piston rings
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Using or losing it?
    How many miles do you do in that time?
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    78 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    I would get it checked out a quick time!
    Regular Member Craig1985's Avatar
    harwich essex
    That's not good mate
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    If it was leaking that much oil you would have enviromental health on your case by now! it must be using it which isnt good, either piston rings or valve stem oil seals.
    I used to have a fiesta that went through a litre a week, turned out to be piston rings on no 3 cylinder, got shot as couldn't be arsed fixing it
    May 2007
    West Yorkshire
    Is the sump plug still there?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    my mate had a astra he to was putting oil in the engine all the time turned out to be
    piston rings in one of the cylinders it was a bit to fix so he never mended it traded it in
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    they can use as much as 1 litre per 1000 miles when using full synthetic I changed to semi synthetic and it hardly used any in 1000 miles don't know why semi synthetic used less
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
