Results 1 to 10 of 22
Thread: HELPP!! Heaters not working
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Exclamation HELPP!! Heaters not working
    Hi all my heater has stopped working on all speeds there's nothing coming from the vents atall, this happened yesterday but it started working again in the morning and now its gone again.
    Anyone know what this might be, is it a fuse? :S
    I did search on the forum and there's a lot of posts for the motor or the resistor being the problem but my one stops working completely and then starts working normally, its gone again now
    Its the climate control type, any help would be much appreciated
    ITS COLD without heaters
    Engine : 1.9 CDTi
    When was the last time you cleaned the scuttle as it sounds like the motor may have seized or part seized.
    Sep 2009
    luton
    Mileage : 100000
    think i posted the same question twice
    I checked the scuttle drain and this was clear no blockage, and i changed the pollen filter today as it was really dirty
    Any Ideas?
    Sep 2009
    luton
    Mileage : 100000
    forgot to mention the previous owner said he changed the heater matrix before as it previously stopped working aswell so am a bit stumped
    Sep 2009
    luton
    Mileage : 100000
    really need some help with this, if anyone knows how to sort it
    cheers
    Regular Member Jez1516's Avatar
    Oct 2010
    Stoke-on-Trent
    Have u pulled out your glove box to have a look at your resistor and your motor?
    Sep 2009
    luton
    Mileage : 100000
    no i haven't checked the resistor or the motor
    How do i check these? remove the glove box and then..
    cheers
    Oct 2010
    Stoke-on-Trent
    Checking your resistor follow and blower motor follow this, http://www.blower-motor-resistor.co....-resistor.html hope it helps.
    Aug 2010
    Stoke on Trent
    If your blowers only work on position 4 but don't work on positions 1, 2 or 3 then it's the resistor pack... or more specifically the thermal fuse on the top of the resistor pack. This blows when your heater motor starts to seize (difficult to turn). When the motor starts to seize it draws more power through the resistor pack which in turn generates more heat... up to the point the thermal fuse blows. The fuses are available from Maplins (or the internet) for pennies and are relatively simple to change. However before changing you need check and if necessary free-up your blower motor otherwise the fuse will just blow again. There are 9 torx screws holding the blower motor in position (behind the glove box). It's awkward but relatively straightforward to remove. Once out you can strip it down, clean/oil it and put it back together with your repaired resistor pack.
    I did mine several months ago and it still runs perfect.
    Aug 2010
    Stoke on Trent
    Darn double posts... lol
  1. Heaters/Blowers Only Working on No. 5
    By Madison5 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 00:47
  2. Heaters not working
    By MattHD in forum Bodywork & Interior
    Last Post: 4th January 2013, 20:07
  3. heaters not working on signum
    By superjetandy in forum Troubleshooting
    Last Post: 1st March 2011, 17:08
  4. springs helpp
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2010, 21:27
  5. Helpp!!
    By ben2996 in forum Troubleshooting
    Last Post: 20th February 2010, 08:55
