Results 1 to 3 of 3
Thread: leak off pipe
    Jun 2011
    South Wales
    Default leak off pipe
    Hi all,
    im going to attempt my leak off pipes tomorrow due to poor starting. has anyone attempted this job or even got a how 2?
    also, does anyone know what mm pipe i should get?
    thanks in advance
    Jun 2011
    South Wales
    by the way, its a 1.9cdti 120 8valve 2007 doh!
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Have been thinking of doing this for a while now as I've been having starting issues but have not had the chance to look it over yet.
    Was going to order the replacement pipe from VX (P/N - 93196078 or 93178685) not sure which for the Z19DT.....
    Or alternatively try doing it the EBAY way and buy the relative Leak-off piping but again was unsure of pipe size and which unions (t-pieces) to buy in case I inadvertently break any during dis-assembly.
    From what I can make out I'll need 1x90° fitting and 3x 180° fittings.
    Attachment 49384
    Found some piping on EBAY but not sure as to which model this would be for as they do not specify, it's just titled Vectra. The pipe according to the ad is 3.2mm and needs to be cut to size.
    The kit does not contain any t-pieces so will have to source them first to be safe but again don't know what size .
    Will be watching this with interest, and if you do have any luck, I'm sure a HOW-To or any tips/advice would be gratefully appreciated
    Best of luck to you and hope you manage to solve your starting issues.
    Damo
  1. Leak-off pipe t-connetors
    By 19weeman80 in forum Engine & Drivetrain
    Last Post: 16th April 2012, 21:02
  2. leak off pipe
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2011, 23:14
  3. Leak off pipe
    By sigtim in forum Engine & Drivetrain
    Last Post: 25th July 2011, 13:36
  4. Oil leak from the pipe....
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 17th April 2010, 11:56
  5. Leak off pipe
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 20:28
vectra 1.9 cdti 8v leak off pipes
