Results 1 to 3 of 3
Thread: Brake pads, which side??
    Regular Member colalowe's Avatar
    in the North
    Default Brake pads, which side??
    Im fitting my 314 calipers this morning,
    I have noticed on the pads that the pad for the piston has a quarter circle cut out, is this cut out meant to b at the top or bottom of the piston??
    just check the pads you take out should be the same on them
    in the North
    Yep checked the ones on my old set up and they had the cut out at the top.
  1. Brake pads ?
    By jacko52 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 14:21
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. Brake Pads - Which are best?
    By robzc in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2007, 16:17
  4. Brake Pads
    By johnmac in forum Handling & Braking
    Last Post: 22nd November 2006, 23:52
