Thread: Front mount intercooler
    Regular Member DTI Dave's Avatar
    Nov 2011
    st annes
    Default Front mount intercooler
    hey guys, just wondered if this FMIC kit is any good?
    i have a 2.0DTI
    http://www.ebay.co.uk/itm/VAUXHALL-V...item588cb38da1
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Save your money Dave
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As above. On a stock DTi I'd just stick with the stock one. It's the same one they fit to the CDTi and VXR so without serious mods to the intake side of the engine, you won't gain anything.
    Oct 2010
    Darlington
    What you have there is a bar and plate universal front mount. For your car you need the most efficient tube and fin core with least possible pressure drop across the core. There will be a fair bit of work to do with the fitting kit above to fit your car.
    I have used a Hybrid GT core and that alone costs £180 but results are very good.
    Those of you that advocate no improvement to the OE intercooler obviously run without the benefit of an air charge temperature guage.
    On a 150 CDTi Vectra C in standard form it only took a short blast in top gear to have 50 or 60 degrees C. ACT. The stock FMIC is barely satisfactory. At that time the ACT guage scale stopped at 69.9 deg.C. After mlld tuning the guage was regularly off the scale on WOT.
    Now on the same 1.9 CDTi engine with the Hybrid FMIC core which I installed using 63 diameter aluminium tube and some silicon bends/reducers from SFS, ACT is generally never more than 15 C. over ambient and this was a major factor in helping me achieve power outputs ranging from 215 bhp 230 through 240 and 250 bhp to the current 269 bhp and over 400 ft.lbs.
    To get maximum benefit from the FMIC you need least pressure drop and you will need to add fuel.
    Nov 2011
    st annes
    thanks for that info guys.... im new to the vectra scene so enquiring and re searching all sorts.
  1. N/S Front Subframe mount
    By cookie in forum Suspension, Wheels & Brakes
    Last Post: 1st December 2013, 10:47
  2. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  3. question about front top mount components?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 14:41
  4. Hi Front mount intercooler (fmic)
    By total_vxl in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2010, 19:21
vectra c 2.0dti front mount intercooler
