Thread: Car pulling to the right :(
    Regular Member !tf's Avatar
    Apr 2011
    Chesterfield/Sheffield
    Default Car pulling to the right :(
    Long story short. I had four tyres put on the other week and had the car tracked and balanced. On the drive home the steering wheel was at 20 degree angle to go straight and the steering wheel vibrated like mad at 50mph+. I took it back and had it redone(gratis of course) but the car is still pulling like mad to the right if I take my hand off the steering wheel. Now is this poor tracking by the cowboys at just tyres or is it something a little more sinister? Any help would be greatly appreciated. Thanks.
    Btw the car drove as straight as an arrow before just dires (lol) got there hands on it
    Sep 2010
    take it somewhere reliable,.. I had this problem from Kwikfit,.. took it to a great place in Grimsby who sorted the problem without issue
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    How it should be done http://www.wheels-inmotion.co.uk/tec...lalignment.php.
    Another case of muppets not knowing what they're doing.
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Probably idiots in tyre place not having a clue.
    Apr 2011
    Just as I thought guys. I've had a family friend check the suspension and he's gonna jack it up at the weekend and check everything else but he can't see anything suspicious. Booked in for a four wheel alignment by a reputable garage so hopefully that will be the end of that. Just a heads up. Avoid Just Tyres in Chesterfield like the plague. They even put one tyre on the wrong way at first. Cowboys.
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Could be a dodgy tyre - i'd swap the fronts for the backs and see if it makes any difference. What brand of tyre did you get fitted?
    The vibration through the steering wheel is likely to be incorrect balancing
    Check the weights that have been used and ensure they are to 5g intervals
    Have all the wheel rebalanced first
    Extremely incorrect front wheel alignment (tracking) can also cause the same symptoms as incorrect balancing
    Personally, if it is an outlet I have not used before I ask how old their equipment is, and avoid anything over 5 years old
    I also look at it visually, as it should be in very good condition
    As above, tracking is fine between tyre changes
    Have a full alignment carried out first, tracking can then be used to determine if another full alignment is required (most outlets do not charge for a check, only adjustments so decline the adjustment)
    It is also essential after any and all suspension components are replaced
    Apr 2011
    Update. went for the four wheel track and the tracking was spot on. The guy checked all possible components and everything is in order. He seems to think it could be the ****ty tyres on the front and has told me that his girls meriva has just had new tyres on the front and has the exact same symptoms despite being perfectly tracked. Gonna swap the tyres from back to front see if that rectifies the problem. ****ing cars man!
  1. Pulling to the right.
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 23:41
  2. pulling to the left
    By monty2000 in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2010, 23:17
  3. Pulling All Over? please help
    By stubby1988 in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2010, 13:05
  4. car pulling in 2nd
    By Morephun in forum Engine & Drivetrain
    Last Post: 18th February 2009, 02:12
  5. Pulling Out Of The Pod...
    By Mark The Cabby in forum General Chat
    Last Post: 6th June 2006, 23:14
