Thread: Spanner light on startup
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Default Spanner light on startup
    I have the spanner light come on at everytime at startup for a few months now and don't know why. It goes out straight away when you give it a small rev and doesn't come back on. No loss in power etc - 2.2dti.
    Any ideas.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's mean the is a stored fault code but it's not an active fault
    Regular Member billwwhyte1's Avatar
    Nov 2010
    Fraserburgh Aberdeenshire Scotland
    Had the same with my car over the last few weeks, was informed from a few members on here that it could be Glow Plugs, so got new set and changed few days ago, now no spannerlight and car starts better 1st thing in the morning.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by paulvectrac View Post
    dti's don't do that
    It'll be glow plugs matey.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as above bud glow plugs
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Well my dti did it
    Well my dti did it
    Both can occur, but if the light goes out whilst the engine is running then it is a glow plug fault (as detailed in the handbook)
    Another is the camshaft sensor fault
    This can put the warning light on for some time, or flash intermittently
    These are some of the few which only show erraticly
    As above, diagnosis on start up will confirm if it is indeed a glow plug fault
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    O I see thanks for that Nate I understand now
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    Unhappy Spiun out last nite. Now have a fault light.
    I spun out coming off a roundabout last nite, nothing spectacular and I didn't hit anything. Just a slippery road, a bit of an arse twitcher but not serious.
    Thing is, the car went into limp mode for a few hundred yards so I pulled up, switched off and restarted, it started and runs fine but I get a car and spanner light every time I start up, it goes off immediately. The car drives fine, revs as normal, drives as it should. I've been looking around and the concensus seems to be that a spanner light that extinguishes after starting is a minor fault, glow plugs need replacing. Does that make sense? I'll get it booked in for a diagnostic but is it probably going to show up as the glow plugs or is there likely to be something else?
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. facelift vec, yellow steering wheel light with exclamation mark on startup
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 16:55
  3. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  4. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  5. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
vectra c spanner light on startup
