Results 1 to 10 of 11
Thread: My DPF only has one sensor pipe...
    Nov 2011
    Swindon
    Default My DPF only has one sensor pipe...
    As the title really
    Took the DPF off the car to *adjust* it today. There was only one sensor pipe going into it (as well as the temp sensor)
    Once I'd refitted it I looked in the engine bay to find the "black matchbox" with two pipes so I could crimp the smaller one - found a small black box (to nearside of fuel filter, lower down) with wires going in but only one rubber pipe.
    Is my car a weirdo? 2008 (08) Vectra CDTI SRi 150 NAV XP2 Estate
    Regular Member benny's Avatar
    Feb 2006
    dudley
    nope normal ......
    Nov 2011
    Swindon
    So there's two types of DPF? One with two sensor pipes and two pipes on the matchbox, and another type with only one pipe?
    (Weird - all the How2s etc only talk about the two pipe versions)
    Nov 2011
    Swindon
    *Additional weirdness*
    Blanked EGR a week ago, didn't get an EML and no fault code stored in ECU. Gutted DPF yesterday, didn't get an EML or a fault stored for that either.
    Any ideas?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Betty View Post
    Any ideas?
    How long have you driven it for after blanking? It can take up 50miles+ before realises something's wrong.
    Either it has been disabled already or someone may have taken the emissions light out (if it illuminates when ignition on then it's fine). It's an engine shaped symbol.
    Dec 2011
    NEwcastle
    How did you go about gutting the DPF?
    How do you know all the insides are out?
    I've been quoted lots of different prices for getting it done from £150-300+
    If it can be done at home, it will cost me lunch for my mate to help out.
    Nov 2011
    Swindon
    Quote Originally Posted by Gazza4 View Post
    Driven for 400+ miles with EGR blanked, 100 or so with DPF gutted.
    Warning lights all work, no fault codes on the ECU.
    Nov 2011
    Swindon
    Quote Originally Posted by Quirrel View Post
    Removed from car, drilled with longest drill bit I could find, attacked with SDS chisel, smashed out the remaining lumps with hammer and drift.
    The key thing to getting it to fall out is to get the hole all the way through the middle, even if you hammer large screwdriver in, then drift it through with 1/2" SD extension bar or whatever - it's smashing through the middle that makes the job easier.
    Because they are all in a bag in the bin.
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Because they are all in a bag in the bin.[/QUOTE]
    I did that to my last Mondeo, just havent got round to the vectra yet.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Possibly the most pointless motoring expense that was ever fitted to a car. From what I can make out, the DPF's simply store the particulates then throw them out later. They really need to come up with a better way than this as this technology is ****e.
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. boost sensor pipe
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th October 2012, 22:34
  3. Replies: 3
    Last Post: 13th August 2012, 22:25
  4. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  5. Wots the sensor in the intake pipe before tb on a z20net
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 15:49
