Thread: Crank Sensor = Limp Mode??
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Crank Sensor = Limp Mode??
    Hey all,
    My 2.2dti keeps going into limp mode randomly making the car dangerous to drive! My mechanic read the codes and only found the crank sensor has flagged up, but he suggests that wouldn't put it into limp mode. Can anyone tell me if this is true. I cleaned my egr valve out and boost sensor but obviously it's not solved it.
    Also, is changing a crank sensor something I can do on my driveway, and are they expensive?
    Cheers all!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    If you use the on line vaux parts dealers this sensor is around £20, to change one fairly straight forward , to be found at the front of thee engine on the right hand side , below the inlet manifold
    East Midlands
    Well i'll tell you what ,my car (2.0dti)was doing the same thing,had the codes read......
    They were...
    P0122-Fuel Pump
    p0335 Crank Sensor
    P0340-Cam Sensor
    The Mech said that it was almost certain to be the fuel pump knackered,so was resigned to scrapping the car,anyway cut a long story short,i bought a crankshaft sensor and fitted it ,easy job this was 2 months ago and the car is as right as rain,for the price mate i'd get one fitted see how you go.
    Thing that got me though was the camshaft code, apparently it doesn't have one.
    East Midlands
    Can't we get this double post problem sorted,doin my heed in.
    Apr 2009
    Stevenage, Herts
    Thanks for the quick replies guys! I'll look at getting one tomorrow then as I have the week off. Time to dig the Haynes manual out I think!
    north east
    crank sensore = car drives like a pig and sounds like a bag of spanner in a tunble dryer.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by roswell View Post
    Hey you just described my car! Strangely that makes me feel much better lol. I bought a sensor for £32 from Bennetts today who had it on shelf, so may say something. I'll fit it tomorrow on my day off.
    Quote Originally Posted by si_hoss View Post
    Find a different mechanic
    The camshaft sensor failure will simply put the EMS warning on (as the EMS can continue to use the crankshaft sensor)
    However, the crankshaft sensor failure puts all VX engines straight into safe mode
    I've had both numerous time
    Also, when the crankshaft sensor fails it is recommended to replace the camshaft sensor as well, as it will not be long behind
    lincolnshire
    as above , you nearly scrapped a perfectly good car cos your mech knows **** all !
  1. Where is the crank sensor 1.9 cdti 8v
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 05:46
  2. Crank Sensor
    By GCusdin in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:13
  3. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  4. P0340 - could it be crank sensor?
    By rich r in forum Engine & Drivetrain
    Last Post: 25th December 2011, 19:00
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
limp mode crank sensor
what sensor on vauxhall vectra c will put the engine in limp mode
where is the crankshaft sensor on a vauxhall vectra c 04
crank sensor limp mode
vectra c limp mode crankshaft sensor
car in limp mode vauxhall vectra 04
