Thread: front fog bulbs
    Nov 2005
    newcastle upon tyne
    Default front fog bulbs
    hi all does anyone know how 2 change front fog light bulbs any pics would be great. i looked in owners manual & it says to get vauxhall dealer to do it so can anyone help
    Nicking Ya Dinner.
    We recommend you give us £80 for a bulb is more like what Vx means.
    Off the top of my head I'd say its look behind the bumper and take out the fog unit, should just be a case off click click after that.
    Regular Member nickc's Avatar
    Jul 2006
    newport, shrops
    Quote Originally Posted by stevietiger
    hi mate, i did one not so long ago - its easy peasy - twist open the fog lamp cover on the base of the foglamp, flick open the clasps, gently remove bulb - its on a cord connecter type thing with a plastic protective case, pop in new bulb (£3.50 from local car part shop)
    pop it back together job done.
    (i did actually phone the dealer first and spoke to a mechanic/technician who told me to do it myself)
    Northampton
    Just about the easiest bulb change that I had ever done on a Vectra!!! I thought that I had read about the bumper coming off etc. Mine is the facelift version.
    Kev.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    You might need to jack the car up slightly so you can get your head under to see what you are doing. Also an idea to check the plug which supplies power to the fog light unit for corrosion while you are there as mine was so dirty it wasn't making a good connection & needed a good clean up.
    Sep 2010
    depends what your vec undertray is like. Mine is an 08 SRI with no access panel at all. I have to remove the bumper to get access to my foglight unit
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by chewy71 View Post
    Not long changed my fog lights for HID's and had to remove bumper as the undertray was in the way
  1. H3 LED bulbs in front fogs.
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2012, 08:10
  2. Change front fog bulbs
    By KevinG in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2011, 15:02
  3. Front Bulbs
    By bigstorer in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2010, 20:45
  4. Front Bulbs
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2008, 10:02
  5. Front Light Bulbs
    By ZC_74 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2007, 01:13
