Results 1 to 10 of 13
Thread: 3.0 V6 cdti timing belt costs
    Sep 2010
    Dumfries, Scotland
    Default 3.0 V6 cdti timing belt costs
    just after a bit of advice and wondered if anybody had a rough idea how much dealers would charge for the timing belt replacement, and as it's getting near the 100k I guess it needs the valve shims done, so what do ya reckon this might be around?
    I'm sitting down as I reckon the price will be scary, given the belt kit is £250 notes on its own!
    Will probably end up doing the work myself but can't bare the thought of doing the shims, so many bits of the engine in the way!! :P
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    belt? are they not gear driven?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Timing belt an tremsioners take about an hour and half to change on this engine.
    Really easy. An kit can be bought from auto Vaux for £162
    As for checking valve clearance I'd say it's about 2-3 hour job as there is a lot to move out of the way. And then slightly longer if any shims need changing
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Jaspa View Post
    Crank to fuel pump (inc water pump) are driven by internal gears
    But cams are driven from belt an fuel pump.
    Ex an inlet cams are timed to each other by helical gears on cam shafts
    Quote Originally Posted by larann View Post
    Phone at least three dealerships and ask for quotes
    You are quite right about the valve clearances, this appears on the Service schedule for completion at end of cambelt
    Mine was completed under warranty at 90K miles, but was advised the cost (in 2009) would have been about £400
    The labour time was 6 hours but they managed it in just over 4
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I was quoted around £400 for the timing belt, tensioner and a major service, this was at Vauxalist on Lincoln
    autodata states 1.2 hours for the timing belt
    i did mine in about 2 with a cup of tea in the middle
    must be one of the easiest timing belts to do
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    I have receipt for £500 including a full service from a main dealer for mine
    Sep 2010
    Dumfries, Scotland
    cheers for the advice guys, I think I'll do the belt myself and then flick a coin over the valve clearances! To be honest it's just the thought of checking, adjusting, checking, adjusting, checking, adjusting, checking adjusting.... maybe it wont be too bad stripping all the gubbins on top of the engine.
  1. 3.2 V6 timing belt Quote / costs: what do you think?
    By Signum-Steve in forum Engine & Drivetrain
    Last Post: 11th November 2012, 11:43
  2. where to get 19 cdti 150 timing belt kit?
    By ronnie63 in forum The 'Off Topic' room
    Last Post: 25th August 2012, 17:24
  3. 150 cdti timing belt again
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 09:33
  4. 3.0 v6 cdti timing belt
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 15:11
  5. Timing Belt CDTi 120
    By ROB WOODHOUSE in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2006, 23:25
vectra v6 cdti timing belt price
vectra 3.0 cdti belt cost
vauxalist lincoln
vauxhall vectra timing belt change cost
vectra c z32se timing belt change
vauxhall vectra 3.0 v6 cdti cambelt
vectra 3.0 cdti timing belt
timing opel signum 3.0 cdti
timing belt vectra c 3.0 cdti
service intervals vectra c 3.0 v6 cdti
