Results 1 to 3 of 3
Thread: Brake light warning message on display
    Mar 2011
    newcastle upon tyne
    Default Brake light warning message on display
    Hi all,
    Have a vectra c 57 plate.
    On the display it says brakelight,have checked all the lights and have even replaced all the bulbs,still the warning comes up.Has anyone any idea why i`m still getting this message and how to clear it?
    Thanks in advance.
    11 Post(s)
    Double check the rear bulbs.
    There are 2 tail light bulbs on each side of the car. The upper one is also the brake light. Should the upper bulb fail, the lower bulb takes over the role of tail / brake light.
    Rear light positions (from the top down)
    Indicators
    Tail & brake lights
    Tail lights (which then becomes a brake light as well should the original tail/brake light fail)
    Fog light (drivers side only - UK)
    Reverse lights.
    All bulbs are 21 watt single filament bulbs.
    Regular Member Veccy-sie's Avatar
    Nov 2011
    Nottingham, England
    Vehicle : Vectra Elite 150
    Trim : full works lol
    Engine : 1.9cdti 150
    As big dave said mate most new veccy's have the secondary brake light systems built in.
    Test the wiring into the back of the lights as loose connections are a problem due to the bad potholes we sometimes hit. I had this problem and i used to just hit the light and it came back on and stopped the messages , until i then found a loose connection and simply secured it.
    Hope this helps mate
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake light warning message
    By babilon2 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 16:03
  3. "BRAKE LIGHT" Message in display...
    By Westy SRI in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 23:35
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Parking Sensor Warning Light/Message
    By marcdale in forum Vectra C / Signum Troubleshooting
    Last Post: 27th May 2008, 17:13
brake light big dave vectra-c.com
check brake lights in vauxhall insignia
vauxhall insignia brake lights
where is vectra 3rd brake light conection
check brake light astra j 2013
astra j check brake lights warning
braking warning system lights on Vauxhall insignia 2009
https:www.vectra-c.comforumshowthread.php151222-Brake-light-warning-message-on-display
astra check brake light
vectra c brake light digital display
brake light vectra 2009
astra j check brake warning light
