Results 1 to 3 of 3
Thread: petrol injector leaking!!!!
    BEDFORD
    Default petrol injector leaking!!!!
    Hi to all,
    Got a 2005 sri with z22yh. Recently had cam chain go , head of skimmed and new valves fitted etc. Runs perfect now apart from the injector nearest cam chain end is leaking . The injector would leak and gently hiss out fuel under pressure. My spanner man has had it back and played around with it. It now dosnt hiss anymore but still leaks intermittantly. Do these injectors have seals that can be easily replaced or is it a head off job ?
    Any tricks or tips boys ??
    Mollers
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    The injectors sit in a plastic cup in the block, the cups have an o ring which can easily be damaged if the cup is not seated correctly when the injectord are pushed home. I had to replace two of mine a couple of years ago.
    Regular Member boodoo warrior's Avatar
    May 2011
    derby
    sorry to hijack your thread but my cam chains gone i believe, how much did it cost you to get it sorted, (head skimmed, new valves etc) mines a z22yh also
  1. injector leaking
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2012, 13:10
  2. injector no4 leaking.need advice asap
    By will2.0dti in forum Engine & Drivetrain
    Last Post: 8th July 2012, 13:13
  3. Damn car! (150 cdti injector leaking)
    By John LE in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:46
  4. noisy and leaking injector?
    By leeky1 in forum Engine & Drivetrain
    Last Post: 15th May 2011, 23:09
  5. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
