Thread: knocking from the rear driver side please help
    exeter
    Default knocking from the rear driver side please help
    hi all please can anyone help me . i have run out of idea's . i have this knocking coming from the rear drivers side. i have change the arb bushes drop links and the upper control arms . i have also checked the brakes pads plus the hub. it only happens when i go over rough road or left hand bends not the right . my garage says it sound like the lower control arms but i undone them from the hub carrier and i dont have any movement in them . i told the garage that it has only be doing this since they done the brake pipes . but they have said it could be somthing i have changed and they want to charge me to have alook . i cant afford for this thats why i do it myself plus i enjoy it . please help me and give me some ideas what it could be . thank you
    What about the shock absorber?
    Protect the bodywork by using gloves, lift each side and release
    If there is a squek noise then the shock absorber has failed
    exeter
    i will try that now and let you know . thanks m8internet
    exeter
    driver side sound like a woshing /sucking noise. other side you can't hear alot is that right ?
    Sounds like the drivers side shock absorber has failed
    Clean the lower edge off, leave for several hours, check for leaks
    The nearside on mine failed, it made noises for several months, but the noise could not be diagnosed
    It finally failed and started leaking
    exeter
    i did have alook at it today . it was dry but rusty wear its been rubbing on the out sleave . would that make the clonking noise.
    The noise comes from the internal piston
    Under normal use there should be no noise
    When the gas pressure has reduced the piston knocks against the body, the noise is then transmitted to the bush and spring, and in turn to the suspension mounts
    As a result it makes it difficult to diagnose where exactly the noise has come from
    exeter
    i have now changed the arb bushes / rear droplinks / upper control arm/ shocks/ springs and i have checked the lower control arms and trailing arms and there is no play in them. plus i have moved the exaust bracket and i have checked the heat sheild. have anyone got any ideas what else it could be . please please someone help me
    exeter
    could the noise im hearing come from the front end and traveling up the pillar so it sounds from the back ish?. because i did have adviser on my mot for the front drop links and that was about 3 months ago ?
    exeter
    all fixed back end was one shock and 2 upper control arms / 2 arb bushes and the drop links. front was arb bushes and 2 drop links . the car feels like new again
  1. rear door driver side weathering seal issue??
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 11:32
  2. Rear Driver side door
    By dan21 in forum Bodywork & Interior
    Last Post: 15th January 2013, 14:50
  3. Condensation on Inside Rear Driver Side Rear Panel
    By akeem in forum Bodywork & Interior
    Last Post: 26th November 2012, 22:12
  4. Cluncking/knocking from rear drivers side.
    By deeks in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2011, 11:11
driver side rear knocking on a vauxhall vectra c
vectra c knocking from rear drivers side
front drivers side brake knocking like piston knocking vectra
