Results 1 to 10 of 17
Thread: Electrical Gremlins - help needed please!
    Birmingham
    Default Electrical Gremlins - help needed please!
    Folks,
    My Siggy seems to have an electrics gremlin. Something weird is going on.
    Symptoms:
    - The radio/stereo intermittently turns of and comes straight back on (almost like someone pressed the power knob and then back on - doesnt request code after it restarts);
    - The centre displays flickers like mad, you can even see the pulse when the indicator is on;
    - Yesterday, for no reason at all after 5 hours of standing it struggled to start, almost as though the battery was dying. Once restarted it was perfect and was fine this morning and all day today;
    - Earlier this morning, as I put the ignition on the "Check Safeguard" message appeared in the central display and it sort of chugged before it started but then it was OK and the message dissappeared too.
    Weird problem hey but im confident its all related.
    Naturally I want to get this sorted before winter properly kicks in as I often drop my son of too nursery so dont want to be stranded.
    please - thanks.
    Bye bye Vec B
    - Hello Siggy!
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Sounds awfully like the alternator's on it's way out fella. Have you checked the voltage across the battery both on idle and under full load (with everything electrical switched on)?
    Could also be bad earths but my vote would be alternator. Check the voltages as above first to eliminate it as the cause.
    Birmingham
    Yep, the alternator has been checked by 2 completely independent garages and the alternator and battery are fine. The alternator was actually replaced last October.
    Bye bye Vec B
    - Hello Siggy!
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    In that case it sounds like it's bad earth connections. Check the main earth coming off the battery for good clean contact with the chassis and check the two main earths up underneath the front dashboard that they're tight.
    Birmingham
    Quote Originally Posted by Ian-Highlander View Post
    Where am I looking Ian?
    Bye bye Vec B
    - Hello Siggy!
    Full Member gibbon7000's Avatar
    lincs
    Quote Originally Posted by Vaux-Man-G View Post
    Folks,
    Symptoms:
    please - thanks.
    How long has it been like this, The reason i ask is, there was a thread about certain alternators not been compatible with the vec/sig range. Could it be this?
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Birmingham
    Quote Originally Posted by gibbon7000 View Post
    I got the car in August, and I recall I first noticed the flickering display about 3-4 weeks later.
    Another symptom is that sometimes it feels as though its going to cut out when I take off, but then sort of jumps back into life.
    Bye bye Vec B
    - Hello Siggy!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Have u checked the voltage from your battery and your altenator?
    Birmingham
    Its all been checked but, got a print out somewhere.
    Bye bye Vec B
    - Hello Siggy!
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Take the glove box out and there's one up underneath right at the top, you'll see several brown wires coming off a bolt in the chassis, there's another one the same place the drivers side (harder to get to).
    There are other earth points on the car (one behind each of the kick panels and one each side in the boot), but those two are the main ones for most of the dashboard area.
    The most important one though is the main earth from the battery, check the connection is good at both ends.
    The incompatible alternator is a possibility although a lot less likely if the voltages it's chucking out are fine.
  1. Electrical help needed
    By Hodgy in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 22:38
  2. Electrical Gremlins (Reply's welcome)
    By billwwhyte1 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2011, 21:30
  3. lots of electrical gremlins
    By jossyboy in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2009, 07:52
  4. Electrical Gremlins
    By Flubster in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2008, 10:54
  5. Electrical gremlins
    By AMPICK in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2007, 09:12
