Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Lowering 1.9CDTI SRI 150
    Regular Member Rodnoc's Avatar
    East Lothian
    Default Lowering 1.9CDTI SRI 150
    Finally got my car back from the dealers today, vibration problem sorted
    I was thinking about lowering the car a touch, before the car went in and since they have fitted new springs and shocks it now looks higher than before. Probably because everything is new.
    So definetly want to lower it now, I want to lower it (keeping the current shocks - they are new), so looking for some advice on what springs will do the job.
    Regular Member Damian's Avatar
    Market Drayton
    Did my SRi last Friday with some Eibach Pro Lowering Springs from LMF. Just waiting for them to settle now
    East Lothian
    How much of a drop do you get with those ? Did you keep the standard SRI shocks fitted?
    Sorry for the questions, new to this lark. Glad I'm not fitting them
    Market Drayton
    As the SRi is already lower than most of the rest of the models you will only get a 15mm drop. That is the maximum you can go without changing the shocks as well, I have currently kept my standard shocks
    East Lothian
    I assume it was these springs you fitted
    http://www.lmfvauxhall.com/prodCatal...=&deptIndex=14
    Market Drayton
    It was those indeed got them next day as he had one last set in stock
    East Lothian
    Thanks for that.
    Just got to find out the right weight and get them ordered
    Market Drayton
    Should be the same as mine, think it's the third one in the list.
    Just ring LMF to order it, give them the axle weights off the plate on you B pillar inside the drivers door and they will get you the right one
    just fitted a set to Mrs GSi's signum today... top quality springs and a TOTAL transformation from the Elite handling..
    Da"m thing goes round corners now..
    spoons
    Guest
    Guys, Those that have fitted the LMF Eibach Spring Kit, could you please tell me what your gap distance is in 'mm' between the wheel arch and the top of the tyre for each corner of the car....
    I really need the gap distance for
    Front Nearside
    Front Offside
    Rear Nearside
    Rear Offside
    Please help and I have a good reason for asking !!!
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. lowering engine 1.9cdti vectra
    By Milliedog in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2012, 14:11
  3. Lowering Spring for 1.9CDTI
    By higgy1541 in forum Handling & Braking
    Last Post: 18th October 2010, 15:18
