Results 1 to 10 of 13
Thread: after changing radiator, how much antifreeze?
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default after changing radiator, how much antifreeze?
    As above after a complete drain of all water and new radiator fitted how many bottles of anti freeze is needed to fill the system back up? I feel the garage that did the swap has put too much in! The colour is deep strong pink, thought it should be a light weak pink? He said he put two bottles in it all in all to fill the system uo. Does this sound right? Or how can i drain some out myself and top up with water? If they have put too much in and i leave it, what symptoms will i get? or any probs? Thanks
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    2 litres of antifreeze diluted 50/50=4 litres....as you probably already know.I m not sure of the exact amount needed from dry but it cant be that far off.
    The "brightness" of the coolant depends on what make was put it,i know for a fact that the offical VX stuff is a pale pink but other brands such as halfords is a very bright pink.When i first for my car i thought the mixture was too weak going by the colour but i know different now.
    Mybe worth asking what coolant was put in and how diluted it was before you start draining off and topping up with water
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I think the 2.2 takes about 7L of coolant from memory.
    Sep 2010
    Leeds
    Wow 7 litre! It was red carplan antifreeze
    Vehicle : SRi
    Mileage : 137000
    I've just replaced my thermostat and had to replace 5L of coolant so 2.5L of antifreeze. Think 5L of VX long life cost about £13+vat from Autovaux.
    According to the handbook a 1.8 engine (that's what the OP has down in his profile) has a capacity of 5½ litres.
    Don't forget though, you'll never drain the system right down. Some will remain. Best to flush through the whole system with plain water then add 2¾ litres of coolant and then top up with water. That way it gets rid of the old coolant and any crud in the system.
    7 litres of coolant!! That would make the system contain 14 litres with a 50/50 mix of coolant and water
    With manual box, 7.1 litres capacity.
    With autobox 7.6 litres capacity.
    Regular Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Enough to give you protection down to -28 for proper anti corrosion protection.
    Vehicle : SRi
    Mileage : 137000
    No that would mean the system would contain 7L of coolant, comprising of 3.5L of water and 3.5L of Antifreeze
    Coolant = antifreeze
    Water = water
    Therefore a system containing 7 litres of coolant doesn't have a 50% mix of water. It has 100% coolant/antifreeze in it.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. antifreeze
    By matts1185 in forum Engine & Drivetrain
    Last Post: 29th November 2012, 14:02
  3. Antifreeze
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 17:16
  4. Antifreeze
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 23:21
  5. AntiFreeze
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2011, 14:18
how much antifreeze in my 2005 vectra
how much antifreeze in vectra c
how much coolant to fill up vauxhall vectra 1.8
vectra c radiator top up
how much coolant astra 1.9 cdti
how much anti freeze in a vectra 06 cdti 1.9 sri
how much coolant fits in a vectra c 1.8 petrol radiator
how much coolant for vectra 2.2
how much antifreeze z19dth
vectra c 1.9 cdti how much antifreeze
how much antifreeze does my vauxhall 1.9 diesel
vauxhall vectra c 1.9 cdti 150 how much antifreeze
how much water does a vauxhall vectra c take
coolant for vauxhall vectra c 19 cdti
vectra sri 1.8 how much coolant
