Thread: nearside upper & offside lower brake lights
    Jul 2009
    letchworth
    confused nearside upper & offside lower brake lights
    Hello,
    It is quite strange but both the nearside and the offside lower brake lights don't work. I replaced the bulbs but they don't work!!
    Any ideas?
    Panos
    South east
    Does the middle one work? If not then you've got a broken brake light switch; it's fitted to the top of the brake pedal.
    Jul 2009
    letchworth
    Yes, it works!!
    South east
    Take out the bulbs and scratch the metal contacts of the bulbholder with a screwdriver, sometimes they get grey corrosion on them.
    Jul 2009
    letchworth
    Yes I will do now, many thanks!
    There are two tail light lamps on each side of the car and when you press the brake pedal the upper lamp on each side glows brighter to indicate that the brakes are being used. Is that what is happening on your car?
    Sep 2010
    ... only the upper section glows brighter when braking
    Quote Originally Posted by panos9 View Post
    This should only happen if the upper has failed
    With the lamps off, just ensure that when the brake is applied that all three lamps operate
    When they are operated check whether it is the upper or lower
    Next turn the lamps on, this will illuminate all four rear lamps
    Again apply the brake and compare to see whether the upper or lower operate
    Remove one of the upper lamps and compare
    Remove both upper lamps and compare
  1. Replies: 41
    Last Post: 6th September 2012, 20:38
  2. Nearside rear upper torque/reaction arm slight play in a pin/bush
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 12:46
  3. removal of upper & lower grille
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 02:09
  4. Nearside/offside help.
    Last Post: 28th January 2010, 23:28
  5. Irmsher Upper and Lower SS Mesh Grill?
    By Draggon in forum Styling
    Last Post: 9th April 2008, 09:22
