Originally Posted by
chrisgettings
wind the window down first
pop the window switch out and unplug
unclip the handle cover from the top not the bottom theres a clip there to stop you from the bottom ...this will let you get to the 2 screws
at the bottom of the door panel are 2 more screws you need to take out
then
from the bottom of the door first ,,unclip the popper clips you will have to pull the panel if your dont have the tool to do this
when you have pop all the clips off look behind the panel and unclit the door handel
to then take the panel off you lift the panel up and it will come off
if this is the fist time that its been off it will be tight,,,just take your time
