Results 1 to 10 of 17
Thread: Weird temp, gauge behaviour ?
    Aug 2011
    Northampton :-( How the hell did that happen ?!
    Default Weird temp, gauge behaviour ?
    Hi -
    I know something similar to this is covered in a few existing posts, but I have yet to find an answer to my particular problem in any of them, so.....
    1.9 Vectra CDTi 120 (pre-facelift '05)
    My temp. gauge almost NEVER moves off zero, despite the length of journey (did 100 miles last night, with it sat on 0 apart from an occasional feeble movement up to maybe 40 degrees, then back down again).
    Put the BC in to Testmode last night and kept an eye on the coolant temperature reported in there... which I assume is fed by the same sensors that drive the dash gauge... and it was running at 65 - 70 degrees, occasionally up to 80, which feels on the low side of normal I guess... but certainly more than reported on the gauge (zero!).
    I noticed that, at anything below 70 degrees (as reported in the BC), the dash gauge was at flat zero, but even 71 degrees (reported in BC) would move the dash gauge up a bit !. I sat in a layby and cooked it, got it up to 80 degrees (BC) - and lo and behold, the dash gauge was also reading 80 degrees !.
    I started to suspect simply a faulty dash gauge.. but the air from the heater is not nearly as hot as I'd expect, either. Have checked coolant levels etc and no problems there..
    Any ideas please folks ?
    Cheers -
    Chris.
    West
    Replace thermostat
    Regular Member clairey83's Avatar
    Nov 2011
    Dumfriesshire
    Engine : 1.9cdti
    Mileage : 155000 :o
    That sounds like my Astra...and it had had the thermostat removed by the guy before me. In winter we put a plastic feed bag over the front of the radiator (a la ice road truckers ha) and it lifted the temp gauge to 80 most journeys and I actually got heat out my heaters
    13 Post(s)
    Quote Originally Posted by eeyore View Post
    The guage doesn't start at zero though. It only registers from something like 70 deg upwards.
    As suggested though, change the thermostat.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Replace thermostat
    same symptoms myself although a different engine. New thermo solved it.
    Aug 2011
    Sounds pretty definite then - thanks all ! :-)
    Nov 2011
    Glasgow
    Aye exactly what mines was doing, sat at the bottom of the gauge (70') apart from the very occaisonal time it would creep up, changed the thermostat last night and all fixed, now sits at around 85' driving!!
    I got my new thermostat from had who had it in stock, (comes with new housing and temp sender) for £45 and some new coolant at £5, took an hour to change as the hose clips as a nightmare but it's a 'simple' diy job if you're handy with the spanners
    Nov 2011
    Glasgow
    Aug 2011
    Cheers for that Waky :-)
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Everybody seems to be reporting temp gauge probs as the cold weather sets in.
    I rekon its just the weather keeping the temp down.
    my gauge operates normal when the weather is over 10 degrees ish.
    only in the winter does it hardly move.
  1. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Engine & Drivetrain
    Last Post: 9th July 2012, 18:54
  2. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 21:08
  3. signum intermittent blue smoke and weird temp gauge
    Last Post: 2nd June 2012, 20:54
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Weird behaviour...
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 15th January 2009, 18:53
