Results 1 to 10 of 20
Thread: Sounds like metal-to-metal from the rear.
    Birmingham
    Default Sounds like metal-to-metal from the rear.
    When im braking, my rear has started to sound like its metal-to-metal. I have checked the pads and there is loads on it, ive also checked the discs, seem good.
    Are there brake shoes inside the discs? Do they operate under the normal foot brake?? Is that what the grinding sound is??
    Help please, before I strip it all down for a pee in the wind.
    Car is a 2004 Signum 2.2 DTi.
    Bye bye Vec B
    - Hello Siggy!
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Are you sure it's the back? It's more likely to be the little dust shields behind the front discs. Very common indeed, they're a pain in the neck, only an inch or so square hanging on a little arm behind the bottom of the front discs, check them, bend them out a couple of mm and see if the sound goes away. Last time mine did it, it sounded like the whole axle was going to fall off any minute, turned out to be a speck of gravel so small I could barely see it trapped in between the disc and the little shield.
    South east
    There's no shoes inside the disk, the handbrake works on the standard pads. The inside pads wear much more than the outside ones tho, so when you had a look was it just at the outside pad?
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    check for stones on rear crapguard
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    try checking inner pad quite common, outside may look ok but inside down to near metal... did a mates couple of weeks ago same symtems
    Engine : 1.9 CDTi
    As above.
    My rear pad I could see through the wheel looked ok but the inner had about 3mm left on it.
    Birmingham
    I will check the inner pad tomorrow. I checked the outer through the wheel.
    Thanks for the comments guys. It doesnt sound like a stone stuck, its proper metal sounding.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Double post - please delete.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Right, the noise is deffo from the drivers side rear.
    I took the back wheel off today, seems to plenty of pad on inners and outers.
    The only thing I noticed was that the disc protector was incredibly close to the disc so I bent it back so its no where near. Anyway, PROBLEM STILL THERE.
    A bit more of a description, happens under heavy'ish breaking and sometimes normal. Also, when I slow right down and then just roll away, I can still hear the metal sound (almost like a chaffing against metal) until I speed up.
    Its deffo braking related but I cannot pinpoint it!!
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Forum glemlins - double post AGAIN!.
    Bye bye Vec B
    - Hello Siggy!
  1. Vectra-B brakes sound like metal to metal
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2011, 14:42
  2. metal on metal noise
    By neill in forum Engine & Drivetrain
    Last Post: 1st February 2011, 18:33
  3. metal on metal maybe?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2010, 17:57
  4. Rear brakes down to metal after 1 year?
    By paulmatty in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2010, 21:42
  5. It's only a lump of metal!
    By Doug-SRidirect in forum General Chat
    Last Post: 17th March 2006, 13:25
