Thread: Rear washer
    Regular Member Carl83's Avatar
    May 2011
    Basingstoke, Hampshire
    Default Rear washer
    Hi,
    My rear washer is not working very well, what the best way to sort it?
    It mostly does work at all and other times you have to hold it for ages and it barely comes out.
    Any help please?
    Carl
    I take it the front ones are ok?
    Have you tried inserting a small pin into the hole to see if the nozzle is blocked?
    May 2008
    Tyneside
    Could be a problem with the pump which has two outlets, one for front windscreen and one for rear.
    May 2011
    Yeah, front is fine and there is plenty of fluid in the bottle.
    I have tried a pin in the hole several times, which works for a while, but then stops again.
    Any ideas? How much is a new pump?
    Carl
    May 2008
    Tyneside
    Quote Originally Posted by Carl83 View Post
    Carl
    Sounds like it is dirt in the nozzle. On the standard hatch ariel base the washer jet can be pulled out. You could then remove the jet, make sure the pipe is secured so it doesn't fall into the headlining, then flush out the tube by operating the washer. Then clean the nozzle using a pin and blow back through it. HTH
    You're pushing the crud back into the system and when you next squirt the rear screen the crud shoots forward and blocks the nozzle again.
    Do as tridley suggests, or get someone to operate the squirter while you poke the nozzle with a pin.
  1. Rear Washer jet
    By Vectra-c-SRI in forum Bodywork & Interior
    Last Post: 30th January 2013, 01:04
  2. Rear washer jet.
    By burbling1 in forum Bodywork & Interior
    Last Post: 8th November 2012, 22:22
  3. Where's the rear washer?
    By stoneyloon in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 20:56
  4. rear washer jet
    By bret.c in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2010, 15:04
  5. Rear Washer.
    By ashdog in forum Bodywork & Interior
    Last Post: 27th August 2006, 07:43
