Results 1 to 10 of 11
Thread: The job is...................
    Leicester
    Default The job is...................
    Headlamp Washer Installation
    As I will be installing the factory Xenon headlights in the near future, I decided to tackle the job of installing the headlamp washer system as this is a legal requirement for Xenon headlights.
    So here is how it was done
    Bags of Vauxhall parts!
    First, remove the original washer bottle.
    Drill the hole for the water level sensor and re-fit the original sensor from the old bottle.
    Then fit the screen washer motor in the new bottle, and also the new headlamp washer motor.
    Fit the new bottle and connect back up the plugs for the level sensor, and both motors. The plug for the headlamp washer motor is taped up in the loom.
    For the hose clips, you will need to drill 4 holes. One is already there and the others are pre-marked.
    [U]Then of course paint all holes and leave to dry.[/B]
    Clips just then pop in.
    Connect the new hose and follow around the front of the car to the non return valve.
    This part of the job is then complete.
    Bumper
    On the inside of the bumper you will see a pre-marked shape that has to be cut out. I also covered the face of the bumper with masking tape to help protect it.
    Washer jet fitted
    The covers come in a nice shiney black plastic.
    I could have left it like this, but I decided to colour code them in flame red as per the factory option.
    Almost done!
    First, a 30 Amp fuse is to be put in position 9. Mine already had the fuse in place.
    Relay installed in the relay box under the bonnet behind the battery near the bulkhead.
    Cut the hoses to the right length and connect to the jets using the connectors.
    With the lights off, the screen washer spray as usual. Then switch on the headlights and the headlamp washer will spray.
    Job Complete!
    Jun 2007
    Sittingbourne, Kent
    Great work mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Good job.
    Are you putting a self levelling kit on it too I presume?
    Leicester
    Quote Originally Posted by Gazza4 View Post
    Good job.
    All being well, everything will be going in. Should be just as if it was installed at the factory. The only difference is the loom will loom different as I will be using adaptors.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Top job
    Irmscher Insignia CDTI 130
    SCOTLAND
    great job matt
    Regular Member graham a's Avatar
    hull
    very neat job maverick
    West
    very nice work!
    WGAF#5
    Nicely finished Matt
    Regular Member CraigoT's Avatar
    York
    looks good and its a nice grille youve got on it as well
