Thread: Which Way to Turn
    Regular Member Damian's Avatar
    Market Drayton
    Default Which Way to Turn
    I have this box from Diagnostix, I think it is the CR1 Plug & Play
    Which way is anti / clockwise. I need to find the reset point so I can turn it up again, I can't remember what I set it at.
    If someone could draw some arrows on the pic that would be great
    I thought it maybe overfueling as I seem to be getting through a lot of fuel so I turned it what I thought was down one turn then my Management Light came on, so I turned it the opposite way twice and I am still getting the light. I want to reset it and turn it again.
    Is the reset zero turns ??, so if I do 18 full turns from reset it will be set at 18
    Basically look at the end of the module, so the screw is directly facing you.
    To turn it back to it's starting position turn the screw clockwise until you hear a faint clicking. That's it at Zero turns. Then turn back up (anti clockwise) to 12 or 15 complete 360 degree turns.
    Market Drayton
    Cheers AJA will try that
    If I get en engine management light with the box on, and not when the box is removed can one assume the box is faulty.
    Market Drayton
    Could the tuning box be responsible for the exhaust emission light to remain on after the eingine has started
    EVERYWHERE
    Quote Originally Posted by Damian
    When the car was over-fuelling it has probably triggered an error code in the ECU.You may need to take it back to the dealer to have it reset.No amount of fiddling with the tuning box screw will get the light to go out.Don't take it back with the box on!
    Here, there and every where!
    It happened on mine when i first fitted the box. Take it off and get the dealer to reset it. It will have thrown up the "fuel rail overpressure" code. I took mine in for them to check it and they reset it free of charge.
    Market Drayton
    Is my car in limp mode now with this light on as there is barely any power when I put my foot downCheers
    Yup, sounds like it has gone into limp mode. Have you tried it without the box to see if it clears.
    Market Drayton
    Just took the box off, will see what happens on the way into work tomorrow
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I think it's your car complaining that you show clean it! look at the dirt in that battery box, how can you do that to your car? Don't you love her? You heartless beast!
  1. Turn your cat into a dog
    By boba in forum Comedy & Humour
    Last Post: 23rd July 2012, 22:02
  2. My turn - What's in the box?
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 18:34
  3. What happens if i turn this ?
    By Vectra-c-SRI in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 22:37
  4. Oh.......my turn now!!!
    By Caterman in forum General Chat
    Last Post: 23rd August 2007, 18:46
  5. Must be my turn...
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2006, 17:42
