Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: HID MOT regulations
    East Ayrshire
    Trim : SRI XP1
    Default HID MOT regulations
    I got this link from vvoc, thanks to the OP for it. Mods might be worthwhile making it a sticky since there seems to be several posts each day on the subject. This is from VOSA and people can make up their own mind on the subject
    http://www.dft.gov.uk/vosa/repositor...n%20Manual.pdf
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Of I see another hid thread there gonna be illegal and all this think am gonna have a brake down lol
    East Ayrshire
    Trim : SRI XP1
    Quote Originally Posted by paulvectrac View Post
    I agree, hence why I though this would be a good idea. Maybe admin could even put a ban on new HID threads! lol
    I dread to think how many there are by now
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Well purely going by section 1.7 :
    dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system
    Where such systems are fitted, they must work;
    nothing there saying such devices MUST be fitted.
    .. then moving into the inspection techniqure:
    Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
    and into failure reasons:
    A headlamp levelling or cleaning device inoperative or otherwise obviously defective
    NOTHING giving reason for failure due to headlamp washing or self-levelling devices not actually fitted.
    So from that I'd summise that as long as the colour, position, beam pattern and alignment, etc regulations are met, then a correctly fitted aftermarket HID kit will not cause an MoT test failure.
    Jan 2010
    York
    Quote Originally Posted by Handyandy-UK View Post
    My Carlton has passed the last 6 MOT's with them fitted, and that is with reflective headlamp units.
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Has anyone though of usein some other jets for the head light ie of another car and connect in to the washer system
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Those of use who swapped to Insignia screen washer jets could always mount the old V jets in the bumper and hook them in tot he screen washers !!
    But then harping back to those regs as written - it does not say washers MUST be fitted.... only that IF they are fitted they must work.
    Jul 2011
    UK
    Year : 06
    I changed mine and left them on the top next to windcreen going down motorway n oh there's a old washers doh lol
    Planet Earth
    W R O N G.
    See below.
    http://www.dft.gov.uk/vosa/repositor...3-lighting.pdf
    The presence and operation of these headlamp cleaning and levelling devices has been added to the test. Therefore, if a mandatory headlamp levelling or cleaning device is missing, inoperative or otherwise obviously defective, the vehicle will fail.
    This raises the question of whether these checks apply to vehicles fitted with after-market HID lighting kits. These kits convert conventional halogen headlamps to HID Xenon and they are widely sold and fitted to vehicles used on the road. The Department for Transport considers that after-market systems should be required to meet the same safety standards as that applied in respect of these lamps at vehicle Type Approval. Therefore, in order to pass the MOT test, vehicles fitted with after-market HID systems would also need to be fitted with headlamp cleaning and self-levelling systems.
    Its pretty simple - if the car has the devices fitted (HIDS/Cleaner/Leveller system), they must work. If aftermarket HIDS are installed, then as per the link I posted, they too need the additional features like levelling/cleaner.
    Dont forget - the link you posted was for *inspection* and the link I have supplied here is clearly marked as *testing directive* so naturally the testing directive (which determines the pass/fail elements of the MOT) is what will be followed. Whether MOT testers adhere to or circumvent these guidelines is up for debate.
    As with all MOT tests and testers, there will be good and honest ones and also bad and unscrupulous ones.
    There is also this link which shows that aftermarket HIDS have been illegal for a while now too:
    http://www2.dft.gov.uk/pgr/roadsafet...headlamps.html
    In practice this means:
    1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
    2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
    3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
    What cannot speak cannot lie. Hopefully this should clear up confusion about HIDS etc. Thankfully mine are OEM so I dont have to worry
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by VSRI View Post
    W R O N G.
    See below.
    That info has been out for donkeys years. And I've passed mot for past 3 years with hids.
    And no countless other people who have to
  1. House ( internal ) Building Regulations .
    By HITFACTORY1403 in forum The 'Off Topic' room
    Last Post: 19th August 2012, 10:07
  2. new mot regulations?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 13th January 2012, 10:22
  3. Service regulations
    By spoons in forum General Chat
    Last Post: 8th June 2009, 20:04
vectra c hid fitting pdf
