Results 1 to 10 of 15
Thread: Random Ticking noise at startup 2.2 Direct
    Regular Member TheSnowMan's Avatar
    Jul 2011
    Bristol
    Vehicle : Vectra 2.2 Direct Estate
    Trim : SRI
    Engine : Z22YH
    Mileage : 123400
    Default Random Ticking noise at startup 2.2 Direct
    Guys (and girls!) I hope you can shed some light.
    I have a 55 (2006) Vectra 2.2 Direct SRI. When I startup from cold I get a random ticking noise from the left(ish) side of the engine, I'd tried running Wynns lifter juice through it but hasnt changed much. What could it be? I'm hearing alot of horror stories re timing tensioners and the like, but would that kind of noise be all the time??
    Help!!!!!!!!!!!!!!!!!!!!!
    Sounds just like this youtube vid I found
    [ame="http://www.youtube.com/watch?v=d756DQ0M0fc&feature=player_embedded"]Vectra z22se ticking - YouTube[/ame] and goes away after 5 mins or so
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Are u shore that's a 2.2 direct dont look anything like mine sounds like timing chain if am honest well an ajuster or somet hopefully benny will see this and have a listen he is the man also sounds like blowing manifold of balance chain like ibsaid wait for benny
    South east
    The video isn't of his car, he found it on youtube, just sounds like his engine.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    O I see lol I thought it was z22se lol
    Jul 2011
    Bristol
    Trim : SRI
    Engine : Z22YH
    Mileage : 123400
    Thanks for the comments, its the ticking sound thats really prominent and very random.. its sort of tick, tick tickerty tick.. tick tick... Do you think its serious??
    Glasgow
    That definetly is the symptoms of the timing chain/tensioners on there way out better to get it checked ASAP before it throws it and causes damage.
    dumfries & galloway
    check your auxilliary belt first i was having a problem with mine making a kind o tapping noise when i would start up and go away when warm the garage took belt off and noise stopped
    Jul 2011
    Bristol
    Trim : SRI
    Engine : Z22YH
    Mileage : 123400
    Thanks for your comments, I think a trick to the garage is in order.. Anyone know a good one in the Bristol Area??
    S.Shields (Newcastle)
    Its normally just the tentioner which can be changed in less then 3minutes!!! there about 15quid i think.. had it happen to me as well
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    What tensioner are we talk in
  1. Weird rubbing noise on startup
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 20:50
  2. knocking noise on startup
    By simon7257 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 17:17
  3. startup grrr noise
    By andreitone in forum Engine & Drivetrain
    Last Post: 21st November 2009, 16:23
  4. Noise on startup from cambelt side
    By cookie in forum Engine & Drivetrain
    Last Post: 9th November 2007, 12:31
  5. Groaning Noise On Startup
    By VauxVeteran in forum General Chat
    Last Post: 24th December 2006, 04:11
vectra 2.2 direct sri noisy on starting
z22yh tocking noise
z22se ticking on startup
