Results 1 to 10 of 13
Thread: loosing speed in high gears
    May 2011
    sunderland
    Default loosing speed in high gears
    Hi ive got a vectra c 1.9cdti on a 06 plate and recently had a new egr valve fitted. Eml light gone and no black smoke anymore howeve i still feel as though the car isnt pulling properly more so in 5th and 6th gears it struggles to keep a constant speed even if i use the cruise control so i have to keep changing down. No split pipes that i can see and no whoosing noises coming from the turbo any ideas????
    South east
    If it's the 16v version the swirl flaps might be inoperative.
    May 2011
    sunderland
    Sorry i shud have said its the 120 bhp dont think they have it or i maybe wrong
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Likely that the MAF sensor has had it. I heard a lot of complaints about this issue on the Alfa forums, seems to be a common issue.
    Since you've done the EGR, try unplugging the MAF, then take it for a drive. If the power returns, the MAF's ******ed.
    Worth a try
    May 2011
    sunderland
    Smile
    Ok mate cheers for that ill give it a go tomorrow and ill let you know how i get on
    Nov 2011
    Unplug it before turning on the ignition though ;-)
    May 2011
    sunderland
    Smile
    Cheers mate thanks for the advice
    May 2011
    sunderland
    If there is no difference what can i do next there are no fault codes registered
    Nov 2011
    A quick check of all vacuum lines and solenoids would be my next bet. The Alfa collective also had problems with sticking vanes in the turbo due to soot but that usually manifested an overboost fault code in some cases. I only mention this as the CDTI engines are the same as Fiat/Alfa JTD derivatives
    May 2011
    sunderland
    Smile
    Morning just had a quick look under the bonnet and ive found a split vacuum.pipe great advice thanks again for your help
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. 3.0 Cdti sort of lumpy in high gears
    By SignumPhil in forum Engine & Drivetrain
    Last Post: 5th October 2008, 21:16
  3. speed in gears vs rpm
    By rob 2.2dti in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2007, 21:58
  4. 1st to 2nd gears, at high RPM
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2005, 20:43
