Thread: laser tracking help
    Jun 2011
    west mids
    Default laser tracking help
    going to get the car laser tracked ,now theres non sports and sports suspension setup setting on the laser machine which 1 should they use as 1 u put weight in the car 70kg on front seats and 15kg in boot to self level and the other they dont
    now do i just get the standard setup even though mines a 2.2 dti sri
    SRI = Sports Suspension
    Equally, what equipment are they using?
    If it is Hunters equipment then all they need to insert is your VRN
    If they are searching for the generic settings then their licence has expired
    Jun 2011
    west mids
    yeah hunter system but dunno if he knows what setting it was as he had to ask me i said sports bud when he started putting weights in car i was abit miffed as to the reason y thats all as its not got self levelling as its a preface
    Same as mine, no need to add any weights
    The weights are to simulate a typical load of two front seat passengers and small load in the boot
    My personal advice is to check the tyre pressures prior to presentation, if required adjust and set them to standard
    Also, remove everything from the car so that it is pretty much showroom condition
    As I posted some time ago
    I visited a local outlet and they asked me several questions about my car, which did not fill me with confidence
    After contacting Hunters they advised this was due to the outlet not having a current licence and recommended I visit an outlet that did have a current licence
    They also advise this would be recognised by the outlet not having to ask any questions and simply inserting the VRN into their system, which will then appear on the screen and match your vehicle
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    The alignment settings given in VX TIS2000 state that the settings are only valid when 70kg/154lbs are added to each front seat and the car has half a tank of fuel.
    Likewise, if the left and right trim heights (distance between centre of each respective wheel and the highest point of the arch) should not vary by more than 1mm. If the difference is > 1mm, then the difference must be compensated for by adding weights in the boot.
    Basically, adding weights ensures the car is levelled horizontally.
    Cheshire
    This is almost laughable, I had my vectra on a hunter machine and the adjustability and accuracy is awesome, the rear track and camber adjustment would be difficult without this awesome kit.
    mine has eibach lowering springs so i guess that would further invalidate the settings, any way we set my GSI to the sports settings then optimised the front camber to max neg on the tolerance. Similar on the rear corrected the trust and brought the rear toe to max out but within tolerance.....................awesome machine(Hunter), my car is superb, tyre wear is exactly as i expected...............and the steeering is perfectly centered don't get hung up on the perfect weighting you wont ever notice the difference the 70kg might have made.
  1. Laser Eye Surgery
    By Vectra_Wilky in forum General Chat
    Last Post: 19th January 2013, 21:00
  2. Laser tag with my son and he's mates
    By Envy in forum General Chat
    Last Post: 13th February 2012, 00:04
  3. 4 wheel hunter laser tracking
    By kman247 in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2010, 23:09
  4. Laser eye surgery?
    By Dose in forum The 'Off Topic' room
    Last Post: 6th May 2009, 21:54
  5. Laser Eye Treatment
    By T4M in forum General Chat
    Last Post: 20th December 2007, 16:45
