Results 1 to 10 of 17
Thread: Warm air from engine when its cold
    Regular Member Mikey4996's Avatar
    Mar 2011
    Aberdeenshire
    Default Warm air from engine when its cold
    Good morning folks.
    Just a quick question, i remember seeing on here that the vectra has a cool thing that it gives out warm air as soon as its started if its cold outside. I've noticed my mates vxr does it but my sri doesn't.
    Would this be a sign of a faulty thermostat? I have noticed that temp gauge takes a while to rise if its cold and you have the heaters on full, and also it goes down when sitting in traffic with the heaters on.
    Cheers for any help.
    Sent from my iPhone using Tapatalk
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Petrol or diesel your car mate
    Mar 2011
    Aberdeenshire
    Oh sorry its a 08 1.9 diesel 150.
    Would it just be the petrols that do this?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Does you m8 have climate control on his VXR? Think the vecs/sigs with climate control have this function, but I'm not sure about the rest.
    Mine has it
    It is known as the Window demisting and defrosting
    It does take a while to warm up though (between 30 and 90 seconds)
    It is the switch directly above rear window and mirrors heater switch
    The fans run at full speed, directs the hot air upwards towards front screen
    You then MUST turn the temperature to HOT
    With the Air Con ON, this operates as demisting
    With the Air Con OFF, this operates as defrosting (although I have not noticed any difference as I run with the Air Con ON all the time, but it does switch off once the outside temperature is too cold)
    You then MUST turn on the rear window heater (bizarre)
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Mine has it
    Interesting cheers.
    Might use that button now. Tried it a few times but annoys me how loud the heaters are lol
    Mar 2011
    Aberdeenshire
    Quote Originally Posted by Gazza4 View Post
    Yeah mate, i'm pretty sure it does, that may be the answer. Lol
    Just as an addition, I do not have Climate Control
    I have also noted in the handbook that not all models have it, but from what I can work out it is standard on all SRI
    However, no mention of it in the sales brochure
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    And to confuse matters more, my CLUB cdti has this too.
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    My siggy elite has dual zone climate and if I press that button with in a bout 20 to 40 seconds it's blowing warm air
  1. Replies: 8
    Last Post: 1st July 2012, 21:27
  2. Very lumpy cold and warm startup and grey smoke
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 5th July 2011, 22:33
  3. 2.2 direct engine starts cold but doesn't warm?
    By barnesy in forum Engine & Drivetrain
    Last Post: 19th December 2010, 12:09
  4. DTi starting issue when warm (not hot or cold)
    By James24 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 20:28
  5. Topping up engine oil... engine warm or cold?
    By Quinten in forum Engine & Drivetrain
    Last Post: 15th May 2008, 18:39
vectra c hot air engine cold
