Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: No compression in cylinder no.1
    Regular Member boodoo warrior's Avatar
    May 2011
    derby
    Default No compression in cylinder no.1
    hi, wanting some advice, went out yesterday, drove about 3 miles when car just cut out on me as i slowed down as i went off a slip road, spanner light was on, got it started again drove about 100 yards and it cut out again, managed to park it up somewhere safe but couldnt get it started again. called the AA out who hooked it up to a fault code reader but none were recorded so he took the plugs out ( o i have a facelift 2.2 direct auto) and did a compression test where he found no compression at all in cylinder n0.1 but 2,3,4 were all fine but car wont start at all. does anyone know what could be causing this and a ruff idea of the likely cost to get it fixes.
    thanks
    nick
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Did he put a drop of oil in to see if gained compression?
    If you get some with the oil in then it's piston rings.
    But to have zero compression is very weird.
    Could be burn out valves. Damaged head/ block etc.
    You could get a garage to do a leak down test to see if they can find where its leaking
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Could be stuck open exhaust valves maybe?
    May 2011
    derby
    no he never put any oil into it, im stuck really till i can get some cash together cuz the AA guy rekons a garage will have to strip it down which is gona cost me even if i cant afford the fix. pants as xmas is coming up n im getting married next year so finances very very tight.
    could it be the timing chain as i did mention to the mrs that i thought i could hear a rattle which wasnt normally there and rekoned to her that i may need to get the timing chain done.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    They shouldn't touch your car with out ur approval. We would do a half hour check then call you
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    i would say that your cam chain slipped a tooth which stopped the car originally then when you started the car again, the timing was out which has resulted you in bending a valve. if this is the case i would guestimate from a garage £800 ish if mildly mechanically minded £300ish, another option like i say if the above has happend,give benny a shout he isn't far from you and he will do the cam chain for you at a good price, then get the head looked at by a head specialist.
    sorry for being a dumb ass just realised you in Derby not Dudley(too bloomin' early for me).
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Wiered one that is as above possible chain slip hope you get it sorted mate
    Regular Member signumturbo04's Avatar
    SCOTLAND
    maybe dropped a valve as opposed to bent one?
    May 2011
    derby
    so if its a cracked head what cost am i lookin at and if its valves what costs that
    Nov 2007
    telford,
    i doubt that the head is cracked m8,i would still be going with my other reply about a bent valve being the cause of no compression, and your cam chain slipping as the cause of the bent valve.
  1. No compression cylinder no4
    By r9 nml in forum Engine & Drivetrain
    Last Post: 23rd November 2012, 19:43
  2. 2.0 dti won't start no compression
    By Nathan1577 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 09:56
  3. Engine Compression
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 22:00
  4. compression z22se
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 20:56
gained compression in cylinder
cylinder order on vectra vxr
sri vectra no compression on 2 piston
no compression internal engine fault vauxhall zafira
renault laguna 2000 no compression 1 cyinder
opel corsa 1.6 has no compression
no compression astra engine
