Thread: Vectra 2.2 dti (2003) alternator
    Sep 2011
    Great harwood
    Default Vectra 2.2 dti (2003) alternator
    Hi all,
    My alternator has packed in on my 2003 vectra 2.2dti,
    Does anybody know of the cheapest place to get one from? New or recon.
    Preferably somewhere in the north west.
    I'm thinking of fitting this myself with some help from a friend, is it a pain to do?
    Any tips, ha ha
    Regular Member benny's Avatar
    Feb 2006
    dudley
    silly question you 100 % its gone ?..........check the bottom pulley or tenstioner aint failed
    Sep 2011
    Great harwood
    Well I'm not 100% on that but from all the warning lights that lit up on the dashboard, and a bit of research on the net, it seems to point to the alternator ready for packing in?
    The lights that came on are a steering wheel with an exclamation mark, traction control light stays on, battery light came on for a while, abs light came on for a while aswell, and the car felt bad to drive.
    Also I've noticed that on starting the car in the morning the headlights flicker, and don't look as bright as they should. I've just replaced the bulbs aswell.
    Does this sound like a faulty alternator?
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    do as benny says could be just your belt and tensioner that has given up the chase and needs replacing.
    Sep 2011
    Great harwood
    Ok will try this, sorry to be thick but how would I go about doin this?
    Sep 2011
    Great harwood
    Will it be obvious if the belt and tensioner are knackered?
    What should I look for?
    Jul 2010
    take the o/s front road wheel off and then remove the wheel arch lining and the tensioner is sat behind that at the bottom.
    if its past it it will be lose and should have some free play if you move it by hand. check the belt for cracks, splits and tears if this is the case it will need replacing in all should cost you around £40 from the dealers for the parts and its easy enough to change them over your self. hope this helps
    Sep 2011
    Great harwood
    Thank you for your help
  1. LPG Vectra C 2003 1.8
    By Electricdave in forum Engine & Drivetrain
    Last Post: 27th December 2013, 01:44
  2. 2003 Vectra Sri 2.2 Dti
    By Dazzy2006 in forum Cars for sale
    Last Post: 11th February 2011, 10:04
  3. 2003 (53 reg) vectra sxi 2.0 dti
    By ADAM123 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 26th November 2008, 19:18
  4. Vectra C 2.2 Sri 2003(must See!!!!)
    By kev smith in forum Cars for sale
    Last Post: 3rd May 2008, 09:59
  5. 2003 Vectra 2.2 sri
    By speedo in forum Cars for sale
    Last Post: 31st December 2007, 11:33
