Thread: diesel leak
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default diesel leak
    im getting a diesel smell coming into the car when driving. I've had a look in engine bay can i can see diesel under the boost sensor so is it coming from the injector because i did loose that when i changed the filter to get car started again when cars engines running i cant see any leaks around that area or could it be leak off pipe
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    I get that noticed it when i changed the fuel filter, think its the little rubber seal on it, i have tried 3 new rubber seals still the same thats 3yrs now and i still see it not dripping but sweating at the seal..
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    You said filter, do you mean fuel filter? I had a leak on mine because i didn't tighten the fuel filter cap enough when I replaced it.
    I had to use a vice to tighten it properly and it stopped leaking.
    Oct 2009
    Sandwell
    yea fuel filter. Its not leaking from the filter its by the injector is there a seal then on or the bolt? Is it diesel thats in the leak off pipes?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. diesel leak
    Last Post: 6th January 2013, 22:53
  3. diesel leak - any advice
    By mooney in forum Engine & Drivetrain
    Last Post: 13th February 2011, 20:16
  4. Need urgent help with a diesel leak
    By the_wave_rider in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:42
  5. diesel leak ??
    By danceade in forum Vectra C / Signum Troubleshooting
    Last Post: 12th February 2008, 02:09
