Results 1 to 10 of 17
Thread: upgraded to 314mm brakes, now no pressure.
    Jul 2011
    Devizes
    Default upgraded to 314mm brakes, now no pressure.
    I've just changed the calipers, disks, pads and hoses on my 05 1.9 CDTI 150 and I can't get pressure back into the system.
    I've bled the front brakes (not touched the rears) using an Ezibleed kit and the pedal sinks to the floor. After a few pumps it firms up, then after leaving it a few seconds there is no pressure again.
    It's the same with the engine on or off. I've checked all of the joints, everything is tight and no obvious leaks.
    Any thoughts as to what could be up?
    Many thanks,
    Mark
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Re bleed ALL the brakes
    And go from their.
    If its same clamp front flexi pipes an see if pedal stiffens up
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    And go from their.
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    is the pedal firm with engine off?
    South east
    Quote Originally Posted by plasma View Post
    No, he said it's same engine on or off.
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    ah, my bad, in that case, bleed and bleed again, including the rears, if air has managed to work its way back to the top then the rears will need doing too..
    Silly question, are the calipers fitted with bleed nipples to the topmost of it?
    gwent
    If bleeding brakes you must as bleed front right and left rear as they are on the same circuit and then front left and rear right as if you brakes fail one circuit should still work
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Its been a while but you should bleed the furthest away from master cylinder first and then what wayne10244 says cross bleed..i dont like these bleed tools nothing works better than the old foot and spanner trick.. Definitely sounds like airlock to me..
    Foot trick.. Two man/woman job.. pump pedal up then undo nipple while pressure is on then when pedal on floor re-tighten nipple lift pedal and repeat till no more air.. Just fluid. Hope this helps.
    Sep 2011
    Staffordshire
    Double post bug
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    also if calipers are on the wrong side bleed nipple will be below the airlock thus no pressure/spongy pedal, best to check silly things first
  1. 314mm brakes
    By bish in forum Handling & Braking
    Last Post: 26th February 2010, 22:23
  2. Upgraded Brakes
    By sycho666 in forum Handling & Braking
    Last Post: 4th September 2008, 19:19
  3. BIG brakes 314mm
    By kenny1zero in forum Handling & Braking
    Last Post: 27th July 2008, 23:02
  4. Upgraded rear brakes
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 19:26
  5. upgraded brakes
    By aerodynamic18 in forum Handling & Braking
    Last Post: 14th September 2007, 21:37
