Results 1 to 10 of 11
Thread: Installing 314 callipers, which way??
    Regular Member colalowe's Avatar
    in the North
    Default Installing 314 callipers, which way??
    Hi all,
    I have a set of 314 callipers and carriers to fit to my 1.9CDTi the question is are they supposed to be fitted to a certain side or can you fit the calliper and carrier to any side??
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Not sure but i would have said they are sided every one i have ever fitted the bleed nipple and brake hose are at the top.. Im sure some one will come on with a better idea..
    in the North
    Ah just looking at them now and that makes sense!! :-)
    Cheers for that.
    in the North
    Cheers for that.
    Sep 2011
    Staffordshire
    No worries...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep the bleed nipple should go to the top to let all of the air out when bleeding
    in the North
    Thanks for the advice, callipers fitted with bleed nipples at the top, they bled very easily and work a treat!:-)
    Regular Member benny's Avatar
    Feb 2006
    dudley
    to be fair you shouldnt be doing a job like this if you have to ask what way round the calipers fit ..your life depends on these and i would get someone who knows what there doing to fit em ....
    Glasgow
    Quote Originally Posted by benny View Post
    +1 My thoughts exactly although we will now get shot down in flames
    in the North
    its not a complex job, the callipers are exactly the same apart from the bleed nipples are in a slightly different place, at first glance its not really noticeable, especially if you don't change brakes everyday, so to be sure I asked the question, rather look stupid and be safe.
    I've since found out I'm not the first on here to have had the problem :-)
  1. sticking callipers
    By gstore in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2013, 14:22
  2. callipers painted
    By daddyjay in forum Quick Photo Album
    Last Post: 12th April 2012, 16:09
  3. rear callipers
    By m1ke823146 in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2009, 09:16
  4. brake callipers 2
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 23:27
  5. callipers
    Last Post: 2nd February 2008, 22:38
