Results 1 to 10 of 18
Thread: Code reader software
    Sep 2011
    kent
    Default Code reader software
    Hi all, have done some searching regarding this topic and have done some "googling" but cant really find anything that helpful.
    I have recently purchased an ELM 327 usb reader (also does live data) I have used Scantool.net which came with it (guessing its not a full programme as some aspects of it arn't available) It is telling me that their are no codes to read, covering previous/pending/current etc? can this happen or could it be non compatible software? I was under the impression that codes were stored in the cars ECU?
    Also can anyone recommend any software that I can use with this ELM 327 device? and is there anyway I can turn the "CHECK BULB LIGHT" off? all my bulbs are working but I have recently changed the brake lights as both rears wern't working... Thankyou
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    if its the bluetooth one and you have an android mobile phone search in market place for an app called torque
    Sep 2011
    kent
    USB one unfortunately, my own fault as was one of them "quick buy" situations... had i done a little more research I would have got the bluetooth one as I'm on a Android HTC lol!
    Main thing I need to find out is "have I got no codes, or is the software not picking it up"
    Forgot to mention, Car is a Vectra C 02 plate 2.2 petrol
    Feb 2011
    Selby
    In general, most ELM327 based readers can only read and interact with the engine ECU (P-codes).
    On the Vectra there are several ECUs, which control and store codes for different systems (eg body control, ABS, security etc), but you will require a code reader that knows how to talk to these Vauxhall specific ECUs - for example Tech2 or OPCOM.
    Obviously the bulb warnings are nothing to do with the engine, so Scantool etc won't be able to read that.
    Sep 2011
    kent
    Thanks Rich, would something like this be ok? also do you know if it would be able to turn the bulb warning light off?
    http://www.ebay.co.uk/itm/Opel-Vauxh...item2eb8578b9e
    Vectra-sport Admin
    Vehicle : VXD
    as your running a htc go for one of these it will work with your phone and also your laptop if its bluetooth enabled and comes with some software for the laptop.
    I know a few people who have one and i`ve seen it working first hand it will check fault codes and allow you to clear them all you need to do is download that app i mentioned earlier called torque
    http://www.ebay.co.uk/itm/Wireless-B...item3cbdc76967
    May 2011
    bispham, blackpool
    Quote Originally Posted by Alansvecky View Post
    hong kong rubbish wouldnt bother it says item location manchester then look at his contact details hongkong it will work 2 or 3 times then break everything i have bought from their does this
    type in item number110775122940have a simular one from different seller its paid for it self 10 times over up to now only had it for 6 mth as well works all sorts of vx
    as for bulb warning it would work out cheaper to buy the bulb and change it
    Sep 2011
    kent
    Quote Originally Posted by 6009tristanb View Post
    Well spotted thanks mate!
    As for the bulb, My brake light bulb had gone, so changed it, but the bulb warning light on the dash hasn't gone out. Every bulb round the car, inside and out is in working order hence me after getting the warning light turned off? or should it turn off once new bulb is fitted?
    May 2011
    bispham, blackpool
    odds on another bulb has a fault might be still working but it will have the fault
    mine was the rear left brake light bulb changed it still had bulb warning light and it kept on popping up on the screen left brake light in the end i changed all 4 back brake light bulbs at the same time (2 in each side)
    as someone on here told me one of the bulbs might appear to be working but somewhere their will be a little fault on one of the bulbs once i did that it went off i dont think i needed my fault code reader to turn it off im sure it did it on its own
    Sep 2011
    kent
    Well they all defo work ok so i guess its either wait for 1 to blow or take them all out an inspect them lol????
  1. code reader
    By dmat1uk in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2012, 14:48
  2. Birmingham - Code reader / live data reader
    By awilson1234 in forum Engine & Drivetrain
    Last Post: 26th September 2011, 16:55
  3. code reader
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2011, 19:25
  4. Code reader, and engine management software
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 13:54
  5. code reader
    By stevie in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:48
