Results 1 to 10 of 14
Thread: Strange sound when turning wheel from centre??
    Nov 2011
    Northants
    Question Strange sound when turning wheel from centre??
    Hi boys and girls
    Have only just got my car and it has a very strange noise coming from under the bonnet.
    It only seems to happen when the wheels are straight and when I turn the wheel off centre. The noise is like a spring sound?
    Any suggestions or help would be much appreciated!
    Thanks in advance
    Pacey
    Engine : 1.9 CDTi
    Possibly a broken spring?
    Quote Originally Posted by Pacey View Post
    Where did you get it from?
    As above, if you are turning the steering wheel and hear a noise from one side only, likely to be a broken spring
    Check the top of the valence cup for the broken remaining part
    Be careful as the remaining spring can be sharp
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    possible strut bearing....Mine is going to get one changed tomoz..I get like a twanging noise when turning the steering..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    11 Post(s)
    Could be small pieces of grit between the spring and bottom retaining cup. Happened to mine when I had a similar noise. Garage jacked it up, lifted the spring up and blew all the stones and grit out the cup with an air line so the spring could sit back in the cup properly. Not heard any noise since.
    East Ayrshire
    Trim : SRI XP1
    It might be worthwhile checking your steering knuckle intermediate shaft, A notoriously weak part on most vauxhalls, if you pop the bonnet and look at the shaft where it goes in to the top of the rack, there will be bolts (can't remember if its one or 2) give them a little tweak, I had to give mine a half turn to tighten properly, that gave a spring sound and you could feel a pop through the wheel
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    My money is on top strut bearing my old veccy had a twang noise when turning steering wheel slightly and I could feel it through steering wheel HTH
    Irmscher Insignia CDTI 130
    Nov 2011
    Northants
    Hi guys
    Must say a big thanks to you all really impressed how much knowledge and help I am receiving!
    I will have a look at all the above tomorrow and give you an update!
    Thanks again for all your help!
    Nov 2011
    Northants
    Hi guys
  1. metalic sound when turning
    By Gary B in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 07:39
  2. Strange sound from rear n/s wheel!
    By Chip in forum Suspension, Wheels & Brakes
    Last Post: 1st October 2012, 22:00
  3. Rough sound/feel when turning right
    By inovo in forum Suspension, Wheels & Brakes
    Last Post: 8th June 2012, 23:13
  4. Rubbing/vibrating sound when turning right.
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd July 2011, 10:22
  5. squeak sound when turning left and right
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 22:17
vectra c strange noise when turning right
