Results 1 to 10 of 11
Thread: Vectra c 1.9 8v Opcom Injector values
    Jul 2011
    Glasgow
    Default Vectra c 1.9 8v Opcom Injector values
    Hi , thought id ask to see if anyone could tell me what the correct figures should be ie minimum/maximum readings for the injectors , on a vectra c 1.9 8v cdti 2007 engine code is Z19DT mines at the moment are
    Injector 1. -5.00
    Injector 2. 0.53
    Injector 3. 0.72
    Injector 4. -4.06
    thanks
    Engine : 1.9 CDTi
    Expect the thread to be closed as we dont talk about Op-Com
    But atleast you found 'the right place to ask '
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    TBH he's not discussing opcom. He's asking about figures that any decent code reader could read.
    Can't tell you what the figures should be though mate sorry
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    we have no problem if someone has read codes and wants advise
    Different matter when members ask how to code items or ask for help activating modules
    Irmscher Insignia CDTI 130
    Engine : 1.9 CDTi
    Ah cool,
    From what I remember upto + or - 10 is acceptable (As close to 0 as possible) but as you can see 1 and 4 are wearing more than the other 2.
    Maybe stick some inj cleaner through as that bought one of mine that was at -7 back to -1 on my 16v CDTi
    Jul 2011
    Glasgow
    have tried the forte injector cleaner but made no difference , would it be wise to change number 1 and 4 then do yous think
    Engine : 1.9 CDTi
    Wait till others can give values but you might just be able to get them cleaned/checked.
    Is it causing a running issue as the values look to be within spec.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Are these readings flow rates ???
    I had my F-I-L injectors refurd a few months back , the flow rates should have been 4.5 -5.00 and they were all round 0.5 as the tips were Fooked !
    Wales
    I would get them all cleaned.
    Just out of interest, how many miles on the car?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    This thread suggested that the readings should be between -3 and +3:
    http://www.vectra-c.com/forum/showth...=116974&page=4
    There are some over tips in that thread like changing the injector wiring and checking the injector seals for leakage.
  1. vectra c 3rd injector wiring mod
    By milny 26 in forum Introduce yourself.
    Last Post: 24th March 2012, 21:45
  2. reading injector values opcom
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 15:07
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Found this info. Torqe Values Vectra C Y20DTH , Y22DTR
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 20th October 2008, 01:18
opcom injector test
8v 1.9 cdti injectors
op-com values
vectra c injector privat in devon
1.9 cdti 16v injectors in 8v
z19dth opcom parameters
z19dt injector values on opcom
vectra cdti injector readings
1.9 cdti injector value
test injectoate opcom
vectra c 1.9cdti correct injector readings
injector wiring test opcom
z19dt injector seals
testing vectra c injectors
z19dt injector readings
vectra c .9 cdti opcom readings
opcom normal readings vectra c 1.9 cdti
how to code vectra c 1.9 cdti injectors
