Thread: What is this?
    Regular Member e55ex_rob's Avatar
    Sep 2011
    Basildon, Essex
    Default What is this?
    Hi All,
    Wonder if someone can help me identify what the following is:
    In this picture, i know that the EGR Valve is in the white square, but the part i need identifing is on the under side of the red square:
    Uploaded with ImageShack.us
    Iv tried to get the best pictures i can, but pretty difficult to get a good angle. Much easier to see if your physically looking at it:
    I have a 1.9 CDTi 150
    Rob
    Thats the end of the pipe that connects to the egr valve I think . I had to replace that pipe on my car as it fractured close to that point.
    Edit: Looking at the last pic there seems to be some sort of blanking plate along with the stainless gasket.
    Sep 2011
    Basildon, Essex
    Quote Originally Posted by Rapala View Post
    Thanks Rapala!
    I thought thats what it was, but wasnt sure.
    I remember when i bought the car the last owner said he had the egr blanked off and he did mention that lower section to me, but i couldnt remember exactly what he said.
    Im guessing that the egr has the blanking plate in place as the eml light is on and i have the code come up for it.
    Can only else confirm?
    Cheers!
    Jan 2010
    Leicestershire
    Old thread and you probably have it sussed now - it will come up with P0400 with that blanked off, same as mine has with the pipe snapped!
    Has anyone got any tips for whether you need any special tools for those two bolts? Had a go with a normal 6mm allen key and couldnt get enough leverage on it. Also, what fitting is on the clamp you can't see at the other end that clamps the pipe to the egr cooler?
