Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: What is the most economical speed to drive at?
    Regular Member sheepish's Avatar
    Yorkshire
    Default What is the most economical speed to drive at?
    As the title says.
    I commute 72 miles a day on a motorway and with cuise control at 70mph I get about 42mpg out of a 1.8 petrol. I'm sure the most economical speed is lower but does anyone know what it is???
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    56mph is normally regarded as the most economic speed to drive at
    Yorkshire
    Mmmm, I know thats the speed that's always been quoted, but is that still the case with modern cars???
    newport
    0mph
    dont know to be honest, 56mph seems to be the magic number, but cant see how with different sized engined cars, as well as all the different makes/models of cars on the market today, that 56mph can be correct?
    Regular Member PANDY 3.2 V6's Avatar
    sunderland
    I think they only say that because its the slowest speed where lorries dont have to overtake you. Unless lorries are limited to that for economy reasons.
    In every car i've ever had i seem to get the highest mpg in the slowest speed i can do in 5th without labouring the engine
    sunderland
    Regular Member Grimy's Avatar
    56mph is not an arbitrary figure. It corresponds to the speed at which the air flow around an object changes from laminar flow to turbulent flow. It always occurs at this speed, independent of the shape and size of the object and is therefore the same for all vehicles travelling through air. At this speed there is a sudden drop in the air resistance, a blip in the graph where the general trend is increasing resistance, or drag, with increasing speed. Assuming the only other resistance is from the tyres and that this is similar for all cars then the major force that the car has to overcome is the air resistance. Hence 56mph is the most fuel efficient speed ! No wonder then that car manufacturers publish data for their cars at 56mph as it will show them off at their best !
    Mar 2007
    GB
    It's not the same for all cars. I've seen some individual tests that concluded around 30mph was the most economical speed for that particular car - on a flat road.
    here's just one example I found with a quick search on google http://en.wikipedia.org/wiki/File:Fu...speed_1997.png
    Cheshire
    Quote Originally Posted by Grimy View Post
    56mph is a very very old government test speed as far a i know! The transitional airflow at 56mph is onei have never heard of........but 56mph is about as slow as you should ever go on a motorway.
    Anyway as Pandy says the most ecconomical speed by a massive margin is 1000 to 1500 rpm in top gear without labouring the engine.
    SCOTLAND
    my vec 2.2 petrol auto was best on long run at 70 constant speedon a long drive. The corsa cdti i'm driving now seems better at 40-50mph though have yet to do a long run at higher speeds constantly. (oys of chuffin roadworks all the way to work)
  1. Most economical motorway speed in 6th?
    By FinestJammy1 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2009, 18:10
  2. Drive train shunt at high speed.
    By stickshift in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2007, 16:49
  3. Cruise - More Economical With than Without?
    By 65gilly in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2007, 10:35
  4. 2.2 SRI. Economical ?
    By Vectrafan in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2007, 13:42
z18xe hypernilling
economical speed
what is most economical speed vectra 1.8
