Results 1 to 10 of 13
Thread: Sooty exhaust tips - Y30DT
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Sooty exhaust tips - Y30DT
    I've posted in this section because I believe it's related to my ongoing misfire problem .
    Near side chrome tip (the outside) is lovely and shiny but the off side one is covered in soot, black all over.
    All I know is that the exhaust is a single pipe under the car until it splits at the Y piece and the n/s rear box is larger than the o/s one.
    Any reasons .
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Only reason I can think of size difference is the space around wheel well maybe.
    Are you getting anything coming out of the clean exhaust?
    Perhaps back box internals have started to break up causing a blockage. Long shot like.
    Quote Originally Posted by CritchvxD View Post
    I tend to agree there, sounds like the nearside rear silencer has neared the end of its life
    However, if the internals have failed you can check in several ways for this
    The obvious one is to bang the underside and see if anything rattles inside
    During the hours of darkness, stand behind the car (side on, not directly behind) whilst someone blips the throttle (same as per MoT test)
    If small sparks can be seen coming out then this confirms the internals have failed (equally, you only get this on a diesel)
    Has either been replaced?
    Equally, last time you cleaned them, did you perform this in equal lighting conditions?
    As above, have someone blip the throttle briefly (same as per MoT test) whilst you stand at the back of the car to see if the amount of smoke is equal between both rear pipes
    I find the external alloy is a nightmare to clean, due to the lack of clearance between the alloy and bumper
    I tend to clean it once a year using a J-cloth and T-Cut
    It lasts just a few weeks
    As for the inside, I've never touched it
    In the past I used to jet wash the insides with the engine running, but never again, the water can settle inside the silencer and cause premature failure
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Both boxes look like 46 mile originals, judging by the rusty outer skins.
    I was thinking along the lines of as the n/s box is bigger, it's able to catch more of the soot whereas the o/s doesn't.
    Critch - hand over the end of each tip seems to give similar back pressure.
    I take it that your tips don't show this difference? I'll have a go at what m8internet has suggested - should be fun tonight .
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Im sure this has been covered before, but cant remember when. Im sure it was decided it was common for one to soot up and not the other. Ill see if I can find the post, though neeedle and haystack spring to mind
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by s_zigmond View Post
    Thanks, appreciate it .
    Quote Originally Posted by gtr1000 View Post
    Yes, they are slightly different shapes, take a look under any other Vectra C with twin rear boxes and you will note this
    However in a diesel there is virtually nothing internally in the rear silencers hence why they tend to last longer than petrol equivalents
    As for catching soot, only a visual examination will confirm this, nothing internally should be performing this, and then as above if there is less soot this suggests the internals have failed
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    No mine are both equally as sooted up as each other.
    How ever when idling on cold start I have noticed slightly more smoke from n/s than o/s
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cant find it :-( I know I didnt dream it, so will take another look later.
  1. what exhaust tips to buy ?
    By matrix1979 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 21:59
  2. VXR exhaust tips, where from and how much?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2011, 12:37
  3. Exhaust tips........
    By scotty84 in forum Styling
    Last Post: 26th June 2011, 12:01
  4. Exhaust tips
    By boodoo warrior in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 19:52
  5. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
opel vectra y30dt exhaust
