Thread: Fault Codes P1105 & P105 and now engine management light..can any1 help me out?
    Jul 2011
    belfast
    Default Fault Codes P1105 & P105 and now engine management light..can any1 help me out?
    hi,
    the fault light on my vectra was occasionly coming on so i put it on the diagnostics machine and it read these faults:
    P1105 -barro metric pressure not plausible with boost
    P105
    now the fault light has stayed off and the engine management light has came on...can any1 point me in the right direction of what is wrong wiv my car?
    its a 2004 vectra 2.0 dti
    Regular Member firefox007's Avatar
    Zagreb
    I had these problems.
    Appeared two days in a row, in the same place at the same time while I went to work. This was on the first traffic light after one mile of driving. After that, one month was good and then the error appeared a few days i a row a couple times a day.
    Regular service was a few days later, where we cleaned the EGR and the intake manifold along with the sensor on it. After this, error did not come back, and now I made more than 5,000 kilometers without any error.
    I hope that the cause was just soot, otherwise it is probably due to a vacuum valve which drives the EGR or the clapper on the inlet manifold. If someone has a more specific answer, I'd be very happy to receive information.
    Nov 2010
    Plymouth
    I had a similar problem a few weeks back and read the same fault code.
    I believe that the Barometric pressure sensor measures the external air pressure as some kind of reference value for the boost pressure to be based upon. Knowing this....
    I removed the Barometric pressure sensor, cleaned the electrical contacts blew gently into the hole underneath to remove any loose debris (Scientific I know!). When fitted back it still gave the same fault.
    It then dawned on me the fault may lie with the boost sensor on the inlet manifold. Just removed it, cleaned VERY GENTLY with a small artist brush and some WD40 (or Carb cleaner), refitted it and no fault since and LOTS more power!
    Regular Member Innes's Avatar
    Plymouth
    I had this and the Sensor was at fault.
    I replaced with a brand new one from Vauxhall for £40(ish).
    its located behind the battery box to the left of the MAF. Its only held on with one torx bolt. Heres a pic:
  1. Replies: 13
    Last Post: 20th May 2010, 20:09
  2. New car fault codes and engine management
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2009, 18:47
  3. 2 fault codes p0105 p1105 can any1 help??
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 09:08
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. Engine Management Light, fault doesn't show on U480 scanner
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:51
fault code p1105
vectra c code p105
vectra p105
opel vectra c fehlercode p1105
vauxhall p105
vauxhall vektra p1105-03
vectra c barometric pressure sensor
p105 vauxhall
