Thread: Z22SE Valve Stem Oil Seals
    Sep 2011
    timbuktoo
    Default Z22SE Valve Stem Oil Seals
    Is it possible to replace valve stem oil seals without removing the head? I have a spring compressor for this purpose but there does not appear to be a lot of room on the Z22SE.
    Has it been done?
    Does it require a home made tool?
    Sep 2011
    timbuktoo
    Bump.........
    South east
    Head-off job.
    East Midlands
    Quote Originally Posted by a15nma View Post
    Has it been done?
    Definitely not ,the valves need to come out to fit the new seals.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Their is a draper tool that uses air an presses valves in head to allow to change the seals with out stripping but probably cheaper to get head stripped
    Full Member
    Bristol
    Yes if you can find an adaptor to fit in plug hole and pressure cyd you can remove sping and change seals. You could make one get an old plug take it a part and then weld an airline adaptor to it . Job done.
    Sep 2011
    timbuktoo
    Thanks for the comments. All I need to do is find a tool or lever of some sort to compress the springs as my tool will not fit.
    I'll prob use soft 6mm rope down plug hole then compressed against the head/valves!
    Going to tackle it now........ Watch this space!!
    Sep 2011
    timbuktoo
    FYI
    The Valve Stem seals can be replaced without taking the head off!
    I have a Bergen Two legged valve spring compressor which I removed a leg from allowing me to hook the single remaining leg around the "casting" on the head at each valve location.
    I then inserted app 1 mtr of soft 8mm rope into the cylinder (BDC) via the plug hole then turned the crankshaft to a (TDC) position compressing the rope against the valves - compress the spring, remove the collets and seal as normal..........
    Happy Days
  1. Valve stem seals. Do they go on the Vectra C CDTI
    By smiley-sri in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2016, 06:27
  2. valve stem seals
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 16:51
  3. Replies: 5
    Last Post: 17th January 2011, 09:12
  4. Replies: 0
    Last Post: 30th September 2010, 19:11
  5. z22se EGR valve
    By delboy2028 in forum Parts for sale
    Last Post: 23rd March 2010, 17:45
z22se valve stem seals
z22se valvestem seals replace
valve stem seals vectra c
