Thread: intake leak
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default intake leak
    cdti 150,ive noticed fresh oil on the inlet hose where it joins onto turbo could a slight air leak (un metered air entering) cause a blip in boost on acceleration that im getting ,when i change from 3rd to 4th or 4th to 5th it starts to accelerate an for a fraction of a second looses boost/power then starts to accelerate again as if its overboosting fuel cut ,ive checked everything i can think of an this fresh oil i can see is the only thing thats not right
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Is it the pipe that goes from the turbo to the throttle body..the big black one?
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    no its the hose that comes from air box to turbo ,the oil is leaking where it joins the turbo intake housing thats whats making me think if oil can leak then air can get sucked in
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it actually leaking oil. Or just got a small amount of say most build up in the pipe.
    A small amount would be except able due to positive crank case ventilation
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by Richard.roberts View Post
    Path of airflow is as follows, front of bumper grill to airbox, from airbox to intercooler, then finally from intercooler to turbo and then to throttle body. A small amount of oil, enough to see it on your finger is normal, but big puddles of it isnt.
    damnit confused myself now, is it intercooler then turbo or turbo then intercooler?
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    it prob is oil mist build up but the small oil leak on the hose isnt really the issue ,im just wondering if there is enough gap on the hose joint to let out a bit of oil then air can get back in maybe , my issue is the brief cut in power on acceleration and could a slight air intake leak cause it
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    It's normally Airbox, Turbo, intercooler then inlet. If you have a little oil there then you will need to replace the pipe, VX charge an arm and a leg for these pipes, I wonder why?
    In the mean time, get a pipe repair kit from Halfrauds (about £5), it'll keep the boost pressure in the pipe until you get that replaced.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by plasma View Post
    Inter cooler after turbo as is meant cool air after it has been forced through compressor
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    path of airflow starts at flexi hose hidden up behind wheel arch lining ,to airbox,to turbo,to intercooler ,to throttle body, then prob leak out of the sh**ty swirl flaps that are probably broke cause they are a crapo design
  1. fault codes DPF and Air intake Leak
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 18th October 2012, 22:26
  2. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  3. Air In intake Leak fault CDTI 150
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2012, 21:00
  4. Intake air Sys Leak 1.9 CDTI
    By TonyTM in forum Engine & Drivetrain
    Last Post: 5th May 2010, 20:20
  5. EGR valve and Intake air leak
    By iceeee in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2010, 23:19
vectra c air intake leak
