Results 1 to 10 of 18
Thread: anti-freeze advice
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    Default anti-freeze advice
    Hi all, last week i used an antifreeze tester, and it showed it needed topping up.... so i took 1lt out, and added a 1lt bottle of coolent (which was blue in colour, but said on the bottle suitable for all petrol cars)
    http://www.commaoil.com/productsguide/view/6/301 - coolent used.
    tested it today, and still saying it was a weak solution, so called into wilcos, to get another litre of the same stuff.
    they told me its the wrong antifreeze, and that i need red rather then blue, as they say it will cause rusting.
    when asked it i can just topp up with the red stuff they sold me they said no, and that i will have to now flush the whole system...
    anyone shed any light on this, and if this is right how do i flush the system?
    the stuff they have now sold me is this - http://www.commaoil.com/productsguide/view/6/351
    anyone comfirm this is the correct antifreeze.
    Feb 2011
    Selby
    As a general rule, don't mix different colours of antifreeze. Whilst it's possible that two makes with different colours may be chemically identical, it's unlikely.
    You will have to drain the lot and refill - the procedure in the Haynes Manual is pretty easy to follow.
    For the Vectra C, it's typically red or orange in colour, usually indicating an OAT antifreeze (though the handbook says glycol based, which are usually blue or green). You'll need about 6 litres of coolant for a 1.8, or 8 litres for the other engine sizes. That's going to be made up of 50/50 mix of antifreeze and water for the UK, so if you buy a 4 litre bottle of antifreeze, you'll have enough.
    The genuine Vauxhall stuff actually is pretty good, and isn't any more expensive than places like Halfords. Also if you go along to a Vauxhall dealer and ask for antifreeze for your Vectra, they'll be certain to supply you with the correct stuff
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    Yes agreed i read some where that if you mix them there is a chance of gunk build up and a blockage.. Blue was designed for the old cast iron blocks but now were all aluminium blue is outdated.. Red also acts as a coolant as well as an antifreeze.. And i believe all vx should be 50/50.. There aint much in the branding to be honest..
    http://www.motormania.co.uk/product/...--5-litre.html
    Sep 2011
    Staffordshire
    Dam double posting again grrrr
    Last edited by shane31; 22nd November 2011 at 16:21. Reason: double post again !!!!! Sorry
    Jan 2008
    leeds / wakefield
    they sold me 5lt concentrate - http://www.commaoil.com/productsguide/view/6/351
    so looks like ill have to flush the whole system, should i stick some water through the system too to clean it out? how do you drain it?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Never mix coolants regardless what it says on the bottle. Blue antifreeze is so old school I have no idea why its still available these days. I would defiantly flush the system a couple of time and refill using the Red OAT antifreeze. There is a good write up on Antifreeze in the Traders section, from Opie Oils.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Sep 2011
    Staffordshire
    just give the bottle a rinse and i would personally take the hose off the top and bottom of rad and stick hose in just to wash it through.. Drain and refill with 50/50 red and water..
    Feb 2011
    Selby
    Removing the bottom radiator hose is the traditional way to dump all the coolant out
    Just try to catch as much as possible and dispose of it safely as it's quite toxic to animals.
    11 Post(s)
    Some of the cheap DIY antifreeze testers don't work with certain types of antifreeze. i.e. it will give you a false reading.
  1. anti freeze help
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 22:58
  2. How much anti freeze?
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 13:58
  3. anti freeze help please
    By amir2300 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th January 2012, 01:02
  4. Anti freeze
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2006, 21:24
help and advice which anti freeze for a vauxhall astra 55
