Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Road Angel supply
    Oct 2006
    Suffolk
    Default Road Angel supply
    Where can i easily pick up a 12v supply for my Road Angel Compact in my Signum, planning in mounting it under the windscreen to the right of the steering wheel and would be nice to have the wiring permanent instead of socket outlet near ashtray, any tips ??
    Mart
    Regular Member Perry's Avatar
    Watford Herts
    BE WARNED!!!!!!!!! The Road Angel is not a 12v feed!!! unless it's the Classic version.
    I had to fit a triple cigarette adapter behind the glove box on my golf and used the head unit live etc for that. I then connected the cigarette adapter to Road Angel lead into the Road Angel giving you switched feed to Road Angel.
    The reason you still have to use the original power lead is because the cigarette bit has a voltage reducer built into it taking it from 12v to around 5v if I remember correctly.
    Hope that makes sense.
    Oct 2006
    Suffolk
    you are right (5v ) but i can leave the voltage adaptor on the cable end and get a inline socket for that and wire that to 12v if i can find an easy to get to source.
    Watford Herts
    Maybe use the head unit live and earth? That's what I used on my Golf.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Solder wire into the wires that run from the socket electrodes and run the wires to the back of cig lighter if that make any sense.
    You might have a canbus problem with the stereo idea.
    Oct 2006
    Suffolk
    Is there a 12v supply under the steering wheel dash area ??
    Thats the side i plan to install so it would be nice to pick it up there to reduce cable runs etc.
    If not the stereo must have a 12v source how easy is it to pull it out to get to the back connections ??
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Siggyman
    Yes there is, feeding into the headlight switch are a permanent and ignition 12V. I had posts, and pics, on it when I replied to somebody else's question on the same thing. I'll see if I can find them.
    Oct 2006
    Suffolk
    Thanks Duncan just been reading them.
    Is the correct way to pull out the light switch assembly the same on a 55 Plate Signum ?? i.e push in the knob and turn to sidelight position ??
    I can easily test using my multimeter for 12v on a black wire and find metal to attach the ground wire. Not bothered if permanent or via ignition as it wont really matter as the Angel will only be working while im driving.
    Just out of interest what is Canbus ?? Is this a communication bus ??
    Yes, it's the same way to remove the light switch.
    You'll find a permanent and ignition 12V in there - both on black wires (of which there are three if I remember! One is a CanBus so make sure you get the right one). I had to do the 'pin *****' method to get into the wirer as there is no visible part of the plug to get the meter on.
    You'll find a nice earthing point behind the steering wheel trim - literally the bottom right of the trim under the wheel, right next to the door hinge area.
    Yes, CanBus is the communication bus used throughout the Vec C/Signum. The headlight switch uses CanBus, hence the zillion wires going into it!
    Feb 2006
    Dorset
    Ive got the new road angel and it is 12v , you might be thinking of tom tom , that is a 5 v supply .
  1. Road angel
    By david.91.09 in forum General Chat
    Last Post: 16th October 2009, 17:47
  2. Road Angel For Sale
    By breezephil in forum General items for sale
    Last Post: 6th February 2007, 08:16
  3. Road Angel
    By Rugrat in forum General items for sale
    Last Post: 14th April 2006, 14:41
  4. Road Angel 2
    By vectragadget in forum General items for sale
    Last Post: 13th February 2006, 19:40
