Thread: How would you cure a air lock from fuel pump to injectors?
    Redcar
    Default How would you cure a air lock from fuel pump to injectors?
    Ive unclogged some tissue from my high presure pump on a 1.9 150 and hoped it would fire up but no luck. Could there be a air lock problem as it just kept on cranking and no start. Cheers
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Crack the injectors Mate that will let any air out tighten Bak up when unsee fuel comein out
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Don't try firing a common rail engine with the unions undone!
    Doing that on a common rail engine could do serious damage to yourself or others as the pressure can reach about 15000psi.
    When was the last time the fuel filter was changed and is the lift pump in the tank firing up when turning on the ignition
    Redcar
    The lift pump is fine mate, my car died while driving and had to get it recovered. The pressure is low on the rail and the man thought it was fuel pump. I ordered a fuel pump and as I was removing old one I noticed the connector on the pump was clogged with abit of tissue. I removed this and the car just cranked and cranked and still wouldnt fire. Does disconnecting the battery do anything like reset fault so it will start. I was hoping that removing the clog would solve my problems. Iam just not sure where to go from here now. Please guide me lol
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    From owners hand book -Restarting after running out of fuel is
    possible, but starting behaviour will be
    delayed. Turn on the ignition three times
    for 15 seconds each time. Then start the
    engine for a maximum of 40 seconds. If it
    does not start, repeat the process after
    waiting at least 5 seconds. I f the engine still
    does not start, contact a workshop.
    Regular Member poves's Avatar
    lancashire
    I would make sure the fuel filter housing is full of diesel , I had similar issues a few years back with a 2.2 dti and everyone was saying - diesel's now self bleed ( rubbish)
    As soon as the filter housing was filled with diesel it fired up not long after .
    Maybe even try a tow start in 3rd or 4th gear at low speed .
    lancashire
    This double post bs is getting beyond the joke now .......
    West
    As said fill fuel filter housing & tow start would be the best option imo
  1. 2.0dti Fuel Pump - Need Help Finding Cure
    By JonnyB in forum Vectra C / Signum Troubleshooting
    Last Post: 9th July 2010, 11:16
  2. 3.0 v6 cdti injectors/hp pump part nos?
    By littlejohn in forum Engine & Drivetrain
    Last Post: 13th October 2009, 02:18
  3. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  4. diesel fuel around injectors
    By robinhood66 in forum Engine & Drivetrain
    Last Post: 15th October 2007, 23:42
