Results 1 to 2 of 2
Thread: Found a small bit of tissue when changing suspected fuel pump
    Redcar
    Default Found a small bit of tissue when changing suspected fuel pump
    I finally got a chance to take alook at my car after it was recovered with a suspect fuel pump failure as died during use and was told low pressure. I got to work changing my fuel pump over weekend on a SRI 150. During the replacement I noticed the fuel filter to pump section on the old pump had a block with a small amount of tissue bunged in. I removed the blockage and tryed to turn over car but no luck. I think this bit of tissue might of been used to stop pipe spilling during filter change which is my school boy error :-( Ive also noticed my second hand pump has a woodruff key but my old one didnt. Its defiantely of the same car so I take it my pump is a modified version as it looks identical except woodruff key. Iam just not sure what to do and cant afford to send it to a garage really. Would there be are in system or would the blockage make pump fail. Iam going to finish changing pump over and try a start if no luck where do I go from there :-( Really want to fix it as like my vectra and the forum. Cheers
    Redcar
    Anyone please :-)
  1. changing the fuel pump on my 2.0 dti!!! HELP!!
    By ryanfoster in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2012, 22:58
  2. Small black box with single LED found?
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2011, 23:46
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Finally found a small car...
    By Vaux-Man-G in forum Non Vectra C/Signum Album
    Last Post: 2nd November 2009, 12:30
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
